ARP head studs
Old Jul 11, 2001 | 07:38 AM
bigTom's Avatar
Default ARP head studs
an ls block with a gsr head on it... which bolts to use... the b18c bolts or the b18a bolts?
Old Jul 11, 2001 | 09:18 AM
13secLSVTEC's Avatar
New User
Default Re: ARP head studs (4dr-gsr)
You need LS bolts, head gasket, and timing belt.....
Old Jul 11, 2001 | 09:37 AM
92Si's Avatar
New User
Default Re: ARP head studs (13secLSVTEC)
You should not give out vague information; Timing belt is dependent upon the choice of water pump. LS water pump = LS timing belt, GSR water pump = GSR timing belt.
HTH
Rich
B18B1-Crx
Jun 18, 2011 07:59 PM
jdmdikk
23
Sep 26, 2008 05:13 PM
b18 hatch mike
Mar 4, 2008 03:38 PM
B18 CYA
May 11, 2005 03:11 PM
avividmemory
Jan 9, 2003 03:03 PM
