how many lb of torque is enough?
Old May 19, 2003 | 11:44 AM
fe519's Avatar
Default how many lb of torque is enough?
i was wondering how many lbs of torque is enough or required to break off the big axle nut? im looking for a impact wrench and want to get something that i dont have to worry about not having enough power...
Old May 19, 2003 | 12:58 PM
accordhybrid's Avatar
Default Re: how many lb of torque is enough? (fe519)
If you are trying to take it off then you need to just be able to get it off don't worry about the lbs of tq.
If you are putting it back on then its 181 ft-lbs of tq
Accordhybrid
Old May 19, 2003 | 06:48 PM
jweller's Avatar
Default Re: how many lb of torque is enough? (accordhybrid)
I cant tell you what it takes to get it off exactly, but a 1/2 drive breaker bar with a 5ft cheater wouldnt break mine loose. I ended up paying the guy at the corner garage to bust it loose with an impact. later on I bought the same impact gun he had, with 600 ft/lbs of torque in reverse.
IR 2131A
https://honda-tech.com/zerothread?id=497097
expensive, but definately worth it.
Old May 19, 2003 | 06:54 PM
niedejb's Avatar
Default Re: how many lb of torque is enough? (jweller)
Thats the one I have.
$125 bucks on ebay new.
Havnt found ANYTHING it cant break loose. But I havnt had to do the crank pulley since I've had it. Had to cheater bar it with the crank holding tool.
Old May 19, 2003 | 10:16 PM
fe519's Avatar
Default Re: how many lb of torque is enough? (niedejb)
i know the axle nut is EXTREMELY hard to take off... anyone tried this but is... about 320lbs. enough to take it off?
Old May 20, 2003 | 06:17 AM
Canonm7's Avatar
I got mine off with a 1ft breaker bar, a 5ft pipe, and my 180 lb body. Came off on the first jump.
Old May 20, 2003 | 06:27 AM
Stew Pidasso's Avatar
I'd say they are about a kabillion foot punds but I used one of these...
Old May 20, 2003 | 06:29 AM
Default Re: how many lb of torque is enough? (Canonm7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canonm7 &raquo;</TD></TR><TR><TD CLASS="quote">I got mine off with a 1ft breaker bar, a 5ft pipe, and my 180 lb body. Came off on the first jump. </TD></TR></TABLE>
The hardest part was getting my GF to step on the brakes hard enough...
Old May 20, 2003 | 06:32 AM
twkdCD595's Avatar
Default Re: how many lb of torque is enough? (Stew Pidasso)
a mac 3 foot breaker bar 3/4 inch drive and hardened impact sockets.
I really am not a fan of impacts but mine can make short work of anything... sometimes too much power though.
Old May 20, 2003 | 08:11 AM
ratherbewalking's Avatar
why wouldnt you throw a stock wheel on there or somethiing so you could break it loose while the car is on the ground.... then nobody has to step on breaks
Old May 20, 2003 | 07:58 PM
Canonm7's Avatar
Default Re: how many lb of torque is enough? (ratherbewalking)
Old May 20, 2003 | 08:37 PM
Accord94DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ratherbewalking &raquo;</TD></TR><TR><TD CLASS="quote">why wouldnt you throw a stock wheel on there or somethiing so you could break it loose while the car is on the ground.... then nobody has to step on breaks</TD></TR></TABLE>
we have a winnAr!!
Old May 20, 2003 | 09:38 PM
iam7head's Avatar
Default Re: how many lb of torque is enough? (Accord94DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX &raquo;</TD></TR><TR><TD CLASS="quote">
we have a winnAr!!</TD></TR></TABLE>
definity not..just use the club or autolock bar to hold that brake in place
Old May 21, 2003 | 07:12 AM
D21X's Avatar
Default Re: how many lb of torque is enough? (iam7head)
i hate axle bolts!!!! still cant get mine off!!!
Old May 21, 2003 | 08:18 AM
ib69nu's Avatar
Default Re: how many lb of torque is enough? (D21X)
i used a 3/4" slide thingey (it looks like this --------0- the 0 being the head and it slides) and a 5 foot cheater bar. we broke 2 ratchets and 2 breaker bars, and an impact gun did NOTHING for us.
Old May 22, 2003 | 11:11 PM
Default Re: how many lb of torque is enough? (ib69nu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ib69nu &raquo;</TD></TR><TR><TD CLASS="quote">i used a 3/4" slide thingey (it looks like this --------0- the 0 being the head and it slides) and a 5 foot cheater bar. we broke 2 ratchets and 2 breaker bars, and an impact gun did NOTHING for us.</TD></TR></TABLE>
someone actually tried a ratchet on a 32mm nut???? lmao thats just funny
Old May 23, 2003 | 06:07 AM
v4lu3s's Avatar
RTFM
i found that making sure teh dimple is completely out makes a much bigger diff than the tool used to spin the nut. i pulled 2 axle nuts in about 8 minutes last night, the guy that i was working with spent hours fighting with em a few weeks ago....using a nice punch rather than a screwdriver to pop the dimple out made all the diff.
Old May 26, 2003 | 05:00 PM
Jago's Avatar
Default Re: (v4lu3s)
if your going to do it with the car in the air it's easier to do it with
the car running. That way the break boost works. I'd much rather do
it on the ground with a stock wheel. Less time consuming and All AROUND
SMARTER
But I don't have to since I have a cordless impact.
Old May 27, 2003 | 04:21 AM
Then I would have to put back together the other stuff I had already taken apart. My stock wheels wont fit back on anyway anymore...
Mr.Speed
May 28, 2017 10:20 PM
GoodSkoolRevltn
Nov 30, 2012 05:35 PM
Acidcrakker
Nov 4, 2007 07:44 AM
bigern1970
Jan 23, 2006 09:54 AM
G2DAB18
Dec 29, 2005 12:06 PM
