B18C into EK?
Old May 18, 2003 | 01:19 PM
Hard2Find's Avatar
Default B18C into EK?
hey guys....which wiring harness to use to swap a B18C into a 96 DX?
thanks
Old May 18, 2003 | 01:22 PM
HXMan's Avatar
Default Re: B18C into EK? (Hard2Find)
96-98 Ex will make it easiest for you.
And 96-98 GSR ECU.
Old May 18, 2003 | 02:11 PM
allmtr's Avatar
Default Re: B18C into EK? (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">96-98 Ex will make it easiest for you.
And 96-98 GSR ECU.</TD></TR></TABLE>
very easy. plug and play. plus the wiring is cleaner. the only problem is the harnes goes for a couple hundred
Old May 18, 2003 | 02:21 PM
fowler!'s Avatar
You can use your stock DX harness if you know what you are doing.
Comes out just as clean.
Old May 18, 2003 | 10:34 PM
turbod16y8's Avatar
Default Re: B18C into EK? (fowler)
hey i got a 00 civic ex.. im planning on a gsr swap. what year gsr will plug and play on my harness.? will a p28 ecu work on a gsr?
redintheface
Apr 15, 2004 05:30 AM
GRAVEDIGGER
Apr 14, 2003 11:02 PM
SC61HB
Feb 8, 2003 08:10 PM
1 speedstar
Jul 25, 2002 02:57 PM
