Can a Honda Oil Filter leak?
Old May 17, 2003 | 02:10 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Can a Honda Oil Filter leak?
I've had this random oil leak lately. After 20/30 minutes driving and then coming to a stop, smoke comes out from the hood and sides of the car. (no fire though)
Originally, it was thought that the oil breather tank caused the problem, but that's not it. Oil appears to be dripping onto the header causing the smoke (still no fire)
My neighbor (who says he's a mechanic) stuck his hand under the oil filter and said it was wet there and followed by saying, it only happens after driving a while because the oil heats up & leaks out of the filter.
I changed my oil today for the first time since the new block was installed so hopefully that solves the problem. If not...guess I'll (or D) will try something different
Old May 17, 2003 | 02:12 PM
Reid's Avatar
Global Moderator
Default Re: Can a Honda Oil Filter leak? (RealTypeR)
Just to make sure, are you positive the oil dipstick tube is not leaking?
That is a pretty common place to have an oil leak.
It seems very odd to leak oil out of the block near the oil filter.
Check to make sure the oil cooler and oil pressure sender are installed properly.
Old May 17, 2003 | 03:29 PM
Dr Pooface's Avatar
Default Re: Can a Honda Oil Filter leak? (Reid)
If there was any old filter gasket left on the block it could leak there.
Old May 17, 2003 | 03:37 PM
Smitdog's Avatar
Default Re: Can a Honda Oil Filter leak? (Dr Pooface)
I have seen some OEM Filters @ my dealership come without the gasket on the filter. Just a thought check it out!
Old May 17, 2003 | 03:41 PM
D's Avatar
D
Default Re: Can a Honda Oil Filter leak? (Smitdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smitdog &raquo;</TD></TR><TR><TD CLASS="quote">I have seen some OEM Filters @ my dealership come without the gasket on the filter. Just a thought check it out! </TD></TR></TABLE>
I put the filter on. it had a gasket. whether or not it's tight enough.. well, i duno. It is not leaking from the pressure sending unit either. it is either the o-ring on the breather box, or well, something else around there.
Old May 17, 2003 | 03:47 PM
Smitdog's Avatar
Default Re: Can a Honda Oil Filter leak? (D)
Gasket in tact then has to be something close by. I would think the O ring would be a good chance if not the gasket.
Old May 17, 2003 | 06:32 PM
so far so good after the oil change. We'll see... I guess I'm just burning the previously leaked shiot off now. Maybe I'll get off my *** and wipe everything down tomorrow and see what happens after that....probably not though
Old May 17, 2003 | 08:09 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">
I put the filter on. it had a gasket. whether or not it's tight enough.. well, i duno. It is not leaking from the pressure sending unit either. it is either the o-ring on the breather box, or well, something else around there. </TD></TR></TABLE>
lube the gasket with a bit of new oil (old will work also)...then hand tight on, then after it is hand tight, proceed to tighten it another 1/4 turn.
this will be tight enough.
Old May 17, 2003 | 08:52 PM
splitime's Avatar
Seeing as its a new block, could it be the oil cooler between the block and the filter?
Old May 18, 2003 | 01:28 AM
JUN JDM's Avatar
yea its possible...if its not tight....or something is wrong w/ the gastket on the filter
Old May 18, 2003 | 05:50 AM
SlapSmak's Avatar
maybe the tanker missed the smell of burning oil and was trying to re-live her past???
Old May 18, 2003 | 06:35 AM
Default Re: Can a Honda Oil Filter leak? (SlapSmak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak &raquo;</TD></TR><TR><TD CLASS="quote">maybe the tanker missed the smell of burning oil and was trying to re-live her past???</TD></TR></TABLE>
:middlefinger:
Old May 19, 2003 | 10:30 AM
anyone else?
Old May 19, 2003 | 10:53 AM
Dave-ROR's Avatar
Originally Posted by RealTypeR
(no fire though)
i think D knows how to install an oil filter btw.
Old May 19, 2003 | 11:07 AM
Johnny Tran's Avatar
Default Re: Can a Honda Oil Filter leak? (dawhiteboy)
my thoughts exactly....of course, one would think we knew how to tighten the drainplug on the tranny as well.....lmfao
Old May 19, 2003 | 11:09 AM
Dave-ROR's Avatar
Default Re: Can a Honda Oil Filter leak? (Johnny Tran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Tran &raquo;</TD></TR><TR><TD CLASS="quote">
my thoughts exactly....of course, one would think we knew how to tighten the drainplug on the tranny as well.....lmfao </TD></TR></TABLE>
lol. Ok, no more comment on other things we did know how to do but were too tired/drunk to actually do
Old May 19, 2003 | 12:53 PM
Yeah, almost lost the tranny due to Johnny Tran.
Marc---&gt; who is not complaining about the free help
Old May 19, 2003 | 01:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, almost lost the tranny due to Johnny Tran.
Marc---&gt; who is not complaining about the free help</TD></TR></TABLE>
BISH, thats what you get for letting us (D and I) drink mass beers....
me-"D, you get that tranny drain plug bish? :burp: I need another b33r"
D- "uh, I think so....C00rs owns"
me-"good enough for me....its just marc-e-mark...if you break down in SC, dont call my ***"
D-"sweet"
Old May 19, 2003 | 01:05 PM
D-"sweet"
yeah mang....we'll see you ****** in a few weeks for more
JustCant5topMe
Aug 16, 2013 12:18 PM
b18teggy
Jun 28, 2008 03:41 PM
tdac69
Honda Civic (2001 - 2005)
Oct 28, 2007 04:15 PM
Tim Martin
Feb 18, 2006 01:06 PM
92accordEX4life
Jan 17, 2006 05:30 PM
