Dipstick issues?
Old Jun 27, 2008 | 04:44 PM
b18teggy's Avatar
Default Dipstick issues?
Well this started last month when i checked my oil and the dipstick said i had none, so rushed to my local autozone and bought 4qts of 10w40 mobil one fully synthetic and a K&N oil filter. I was scared cus i thought i was driving around with 0 oil, when i change my oil, 3qts of old oil still came out, so im wondering how come the dipstick told me i had none instead of being short. Now that im checking it, once again it says i have 0, wtf might be the problem, im about to go buy new oil and filter just to be on the safe side. NOTE*** I am leaking oil but im loosing around 1qt a month, nothing serious, im just wondering how come the dipstick started showin no oil all the time.
Old Jun 28, 2008 | 07:55 AM
b18teggy's Avatar
anyone
Old Jun 28, 2008 | 08:12 AM
jwrape's Avatar
Default Re: (b18teggy)
Oh my....
Most dipsticks only show the 1st 2 or 3quarts on the dipstick. It doesn't show the entire oil pans worth. But it sounds like you are burning or leaking oil pretty rapidly. need to fix that soon or you will run it too low and burn it up.
Old Jun 28, 2008 | 02:54 PM
lmike6453's Avatar
Take care of your problem as soon as possible. Is it leaking from the oil pan or rear main? Did you try to change your PCV valve?
Old Jun 28, 2008 | 03:41 PM
prb22786's Avatar
Default Re: Dipstick issues? (b18teggy)
This might sound stupid but make absolutely sure you're on a level surface when you take the reading, and that the dipstick itself isn't warped or bent. Warm up the car, turn it off and let it sit for 10 min, then try taking the reading again. You shouldn't be reading nothing on the stick and have 3 qts of oil draining out.
4everVtec
Dec 18, 2007 10:26 AM
rayzian
16
Aug 17, 2007 06:48 AM
HondaEJ7
Feb 13, 2006 05:18 PM
WiCkeDReX
Dec 9, 2004 12:26 AM
94GsRacer
Sep 19, 2002 02:43 PM
