JDM R Guage Cluster
Which year JDM guage cluster is recommended? Are they all plug and play in a 2000 DC2? Are the 98spec better than 96spec?
The clear plastic shield on the front of the cluster- Is it easily removed/ replaced?
The reason I ask is I am bidding on one on ebay right now and the plastic shield was removed because supposably it has [I]minor[I] scratches. I figured I could just take the plastic off mine and transfer it to the JDM one. Is this a bad buy because the needles on the tach and speedo may have been touched?
Thank you in advance for your help
great questions... i've never ever heard this question asked before in my life before. good thing you asked it...this way once someone replies to this thread to answer your question, it will be searchable using the great h-t search!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSpecR »</TD></TR><TR><TD CLASS="quote">Which year JDM guage cluster is recommended? Are they all plug and play in a 2000 DC2? Are the 98spec better than 96spec?
Thank you in advance for your help </TD></TR></TABLE>
You ask a good question and I hope this will help:
I had a Spoon cluster in my 00' R and the only problems I had was with the gas gauge. The problem was when I had a full tank of gas, the meter read that I had half a tank. And when I turned my hazard lights the speedo jumped up and down between 0-300 rpm's. As for the best choice i'm not quite sure about that, I think matching years would be easiest.
Kurt-
Kurt-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">great questions... i've never ever heard this question asked before in my life before. good thing you asked it...this way once someone replies to this thread to answer your question, it will be searchable using the great h-t search!
and you yell at me for being a wiseass
</TD></TR></TABLE>and you yell at me for being a wiseass
Thanks Kurt for the help- You don't have the Spoon Cluster anymore do you?
It seems that with a 97 spec I need to swap the green film on the back or the actual guages into my cluster... Anyone recommend which one is easier?
Thanks again!
Thanks again!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 »</TD></TR><TR><TD CLASS="quote">
and you yell at me for being a wiseass </TD></TR></TABLE>
[QUOTE=SpoonSpecR]Thanks Kurt for the help- You don't have the Spoon Cluster anymore do you?
Sorry but I just sold it to a guy on H-T, Michael. But I can get them used if you want one? I also have 1 97' spec cluster if you want it? No rush just let me know.
Kurt-
Kurt-
the only difference i see with 96 spec cluster and 98 spec cluster is the srs light and the one next to it (i forgot whats next to it LOL) i have a 95 gsr and im using a 98 spec cluster and everything works fine.
crx_si-r
Feb 22, 2009 02:20 PM
95dxhatch
28
Oct 8, 2004 08:28 AM
