When to shift when racing??
Old May 15, 2003 | 11:45 AM
type_racing_1's Avatar
Default When to shift when racing??
When is the best time to shift in the Type R while racing???
Old May 15, 2003 | 11:49 AM
R-1303's Avatar
Default Re: When to shift when racing?? (type_racing_1)
by looking at stock dyno plots around 8000-8200 rpm..but i redline my **** and i shift a split sec before bounce off the rev limiter...
Old May 15, 2003 | 11:50 AM
98type_r's Avatar
New User
9000rpm
Old May 15, 2003 | 11:51 AM
RTW DC2R's Avatar
Default Re: When to shift when racing?? (R-1303)
if you dont know when to shift, you really shouldnt be racing, or driving a Hype R.
Old May 15, 2003 | 11:52 AM
01ITR#700's Avatar
Default Re: When to shift when racing?? (RTW DC2)
Try to shift right before fuel cut-off. That seems to net the fastest acceleration because it will keep you in VTEC when you shift to the next gear.
M
Old May 15, 2003 | 11:53 AM
Hey Hype R shut your mouth, i was just asking a question you dont have to be a dick about it... HYPE aaaaaaAARRRRR ya big kool guy.
Old May 15, 2003 | 11:54 AM
Champ R's Avatar
Default Re: When to shift when racing?? (01ITR#700)
Max power hits at 8000 rpm, but its best to shift at redline to stay in vtec for the next gear.
Old May 15, 2003 | 11:59 AM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type_racing_1 &raquo;</TD></TR><TR><TD CLASS="quote">When is the best time to shift in the Type R while racing???</TD></TR></TABLE>
I assume you're talking about drag racing.
Old May 15, 2003 | 12:06 PM
zk11's Avatar
New User
Default Re: When to shift when racing?? (Big Phat R)
it's nice if you can install like an LED light where you can see while watching the road that turns on to let you know when to switch, say, at 8000rpm. isn't that like a common thing in a real race car? but usually you can tell from the sound of the engine.
Old May 15, 2003 | 12:07 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type_racing_1 &raquo;</TD></TR><TR><TD CLASS="quote">Hey Hype R shut your mouth, i was just asking a question you dont have to be a dick about it... HYPE aaaaaaAARRRRR ya big kool guy. </TD></TR></TABLE>
You're not going to make any friends with that attitude.
Anyways, when to shift is dependent on what type of driving you are doing (track, autocross, drag, etc).
Old May 15, 2003 | 12:09 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
when you start to hear valves bend.
Old May 15, 2003 | 12:10 PM
RTW DC2R's Avatar
Default Re: When to shift when racing?? (.RJ)
your question was too general, hence, my very general answer
Old May 15, 2003 | 12:15 PM
RiCE On IcE 2's Avatar
why is it in neutral fuel cut off seems to be exactly at the begining of redline but when in gear u can go beyond redline.. I have actually never hit cut off while in gear.
Old May 15, 2003 | 12:18 PM
Hukd Up's Avatar
right b4 fuel cutoff cuzz it'll keep u in vtec and in higher rpm's - when drag racing of course
lose the attitude homie
Modified by Hukd Up at 1:34 PM 5/15/2003
Old May 15, 2003 | 12:26 PM
.RJ's Avatar
.RJ
Default Re: When to shift when racing?? (Hukd Up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hukd Up &raquo;</TD></TR><TR><TD CLASS="quote">right b4 fuel cutoff cuzz it'll keep u in vtec and in higher rpm's
Not always. cuzz it dp3nds what kind of racing you are doin
Old May 15, 2003 | 12:53 PM
hooptie157's Avatar
8500rpm yo!!!!!
Old May 15, 2003 | 01:20 PM
nEoMuGen's Avatar
Default Re: When to shift when racing?? (hooptie157)
For Drag...duh! just right b4 your fuel cut-off
For Autox...for me, the instant moment that I can find a straight line. (situation varies, hard to tell)
For Road Racing...I tend to shift at or near redline, but as long as the condition allows, I find the most feasible region of straight line and in function to the highest RPM rpm range availiable. Redline shifting is not necessarily the best way depend on course lay-out.
Old May 15, 2003 | 01:31 PM
.RJ's Avatar
.RJ
Default Re: When to shift when racing?? (nEoMuGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen &raquo;</TD></TR><TR><TD CLASS="quote">For Autox...for me, the instant moment that I can find a straight line. (situation varies, hard to tell)</TD></TR></TABLE>
Not to mention you dont *always* downshift to keep it in the peak powerband, because shifting wastes time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">For Road Racing...I tend to shift at or near redline, but as long as the condition allows, I find the most feasible region of straight line and in function to the highest RPM rpm range availiable. Redline shifting is not necessarily the best way depend on course lay-out.
Any way to minimize shifts is good on a road course. Be smooth, carry momentum, short shift in 2nd gear turns.
Old May 15, 2003 | 01:35 PM
Tommy_Gunns's Avatar
3000 rpm
gas is expensive
Old May 15, 2003 | 01:57 PM
Boost Ambassador's Avatar
8200 is for dorks n trix are for kids
Old May 15, 2003 | 02:23 PM
KIWI's Avatar
Always Shift before you hit the rev limiter... I Shift a 9000 And I have my limiter set a 9300- The load on the engine internals is much greater by the effect of the Fuel or Electronic limiter cutting in, than using the extra 2or 300 RPM.
Kiwi
Old May 16, 2003 | 11:26 AM
alai2001's Avatar
Default Re: When to shift when racing?? (KIWI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KIWI &raquo;</TD></TR><TR><TD CLASS="quote">Always Shift before you hit the rev limiter... I Shift a 9000 And I have my limiter set a 9300- The load on the engine internals is much greater by the effect of the Fuel or Electronic limiter cutting in, than using the extra 2or 300 RPM.
Kiwi</TD></TR></TABLE>
i've never heard of this before, can someone confirm this?
during my autoXes i've always bounced off the redline.
Old May 16, 2003 | 11:52 AM
Stinkycheezmonky's Avatar
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Be smooth, carry momentum, short shift in 2nd gear turns.</TD></TR></TABLE>
Short shift? What exactly is short shifting, not redlining when upshifting to third?
Old May 16, 2003 | 12:00 PM
DutchITR1689's Avatar
Default Re: When to shift when racing?? (sscguy)
That is shifting before the turn even if you haven't reach redline yet, in the case that you'll reach redline in the middle of the corner.....
Old May 16, 2003 | 02:27 PM
Suspetise...
Default Re: When to shift when racing?? (DutchITR1689)
Ah, gotcha, thanks.
I guess that's for the purpose of not upsetting the balance of the car in the middle of the turn?
