Lifting a civic? RALLY STYLE!
Old May 16, 2003 | 09:45 AM
90wagon4wd's Avatar
Default Lifting a civic? RALLY STYLE!
I have a 4wd civic wagon. It is fun. It has a d16a6 engine, mpfi. I have modded it a bit: 99si rims w/kumhos 15/55/195, exedy clutch, custom mandrel bent exhaust, sparco-copy DAD seats, moved the battery to the back, took out the A/C. I'm in the process of turboing it...I have a hf manifold, adaptor plate, t25 turbo, dsm bov, & side mount intercooler....just need to get a FMU, check valves, & some assorted oil & vaccum lines. I can't wait.
It is alot of fun. I live in WA, and drive on alot of dirt roads, in deep snow, as well as tearing it up the twisties. I want to upgrade the suspension for better handling, on the road & on dirt. I'd prefer not to lose ground clearance...I bottom that **** out all the time on water bars. I know the demands of driving of rutted dirt roads fast, & driving on asphault fast are real different.
The wagons have longer rear trailing arms & shocks than all other civic/crxs, so upgrading them is not easy. The rear sits higher than the front...rear has a 3" gap between wheel well & tire, front has 2" gap. I just want to raise the front 1".
My one thought is to just keep the stock springs & just upgrade the shocks to some tokico blues. I would think the increased damping would help with the body roll under hard cornering.
My other thought is 92-95 civic shocks..they are a bit longer..I've seen people mount them on EFs with shorter springs, lowering them, and losing quite a bit of shock travel. I think if you used stock EG spirngs & shocks it would raise the car slighty.
My other thought is forget about lifting it, and just get my friend who welds offroad stuff to make me a skid plate to protect the oilpan, gastank, tranny & whatnot.
Any ideas?
Old May 16, 2003 | 01:36 PM
NINJASPY's Avatar
Default Re: Lifting a civic? RALLY STYLE! (90wagon4wd)
I am a big fan of ground controls, you should call them and ask if they make an application for your car. They advertise lowering, but I am unsure of raising... but you could always get longer springs from them. Get some decent shocks, gc should have some advice. I also suggest you get some dirt/snow tires and a roll bar/harnesses just incase...
Old May 16, 2003 | 04:35 PM
martini's Avatar
another bellinghamster!
I suggest you call up H&R springs, and see what they suggest. They are quite helpful usually. Tell them you're in Bellingham.
Old May 16, 2003 | 07:24 PM
Louie B.'s Avatar
I read somewhere that 94-00 Integra springs are longer, but they fit.
Old May 19, 2003 | 10:15 AM
90wagon4wd's Avatar
Default Re: Lifting a civic? RALLY STYLE! (martini)
So, I think what i'm going to do is 89-91 shocks, probably tokico blues. With coilovers for a 90-93 teg. Searching around the net, I've found those springs fit, and are longer. Plus the 4wd wagon is about the heaviest civic you can get, & I think the teg spring rate would probably work better.
Ej8 d16
Jan 14, 2015 05:58 PM
JackSparrow
Paint and Body
Jan 7, 2009 05:24 PM
Jwbetley
Jan 27, 2008 11:40 PM
MotorMouth
Classic Hondas
20
Dec 18, 2007 01:30 PM
revhardsi
Oct 10, 2002 10:14 PM
