Classic Hondas All Pre-1988 Hondas.
1978 civic 1200 rear engine right hand drive conversion(pics)
Old 08-22-2007, 07:28 PM
MotorMouth's Avatar
Default 1978 civic 1200 rear engine right hand drive conversion(pics)
ok this project has been going on for sometime. i call it project wheelie. the basic lay down is the rear floor of the car was completely rusted out and could barely hold the suspension any more. so at first i cut out the rear floor board and was going to update the rear suspension with 95 civic drums and trailing arms. well one beer led to another to make it short. i had a just about everything i needed to make it rear engine. im using a stock d16z6 as mock up for the moment.later it will be a built turbo motor. created all my subframing to hold the whole front suspension off of a 95 civic. using aluminum as a floor and 2x2 for the framing. just recently i decided to take it to another level and make it right hand drive. this has made the whole thing extremely interesting now. ill have to explain more later. just wanted to start this thread and see if any other classics are running around modded up.
more to come later
Old 08-22-2007, 08:20 PM
cb07's Avatar
All I can say is that this thing better get finished and get running, because otherwise, what a waste of a classic Honda.
Good idea though, takes some big one's to do it. In for the build!
Old 08-23-2007, 03:13 AM
E-AT_me's Avatar
Default Re: (cb07)
would this be the car i think it is?
if it is, it's definately not a waste cause that 1200 was trashed before they even got it.. if it's not, then i dunno......
Jason?
Old 08-23-2007, 05:09 AM
smithenhiven's Avatar
Default Re: 1978 civic 1200 rear engine right hand drive conversion(pics) (MotorMouth)
wow, this should be interesting to sat the least.
Old 08-23-2007, 06:34 AM
My Name is Nobody
MSchu's Avatar
Default Re: 1978 civic 1200 rear engine right hand drive conversion(pics) (smithenhiven)
so if this is going to be a wheelie machine you'll need independent right and left rear brakes and pedal set ups... I dont see that in your pictures???
Old 08-23-2007, 01:31 PM
MotorMouth's Avatar
Default Re: 1978 civic 1200 rear engine right hand drive conversion(pics) (MSchu)
eat me. yeah this is jason. who are you if i may ask. you were right the car was falling apart before i started messing with it
mschu- thats later. everything is still in the mock up stage.im still trying to figure a bunch of things out. being that im using all 95 civic stuff in a car that is 29yrs old and not made for. theres not even brake lines yet. i was thinking of using clutch master cylinders mounted to 2 e-brake handles. tap them into the rear lines. thats just an idea for now though. you made a valid point on that though. i will have to investigate how other cars of this nature control the rear wheels. im pretty sure most v8s have rear drum brakes or atleast calipers designed to have an e-brake. the calipers on the 78 at the moment are front calipers.
Old 08-23-2007, 01:47 PM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMouth &raquo;</TD></TR><TR><TD CLASS="quote">eat me. yeah this is jason. </TD></TR></TABLE>
haha that takes on a very different context without the the hyphen.
E-AT ME.
Old 08-23-2007, 03:34 PM
E-AT_me's Avatar
Default Re: 1978 civic 1200 rear engine right hand drive conversion(pics) (doublethink)
hence the fun of my screen name....
this is Joey Z..
Old 08-24-2007, 06:03 AM
Needs More Cowbell
newby_j's Avatar
Default Re: 1978 civic 1200 rear engine right hand drive conversion(pics) (E-AT_me)
dune buggys use a hydro. cutter brake.....look into that. it just allows you to hook up the rear hydros normally and use them independently, too.
Old 08-24-2007, 06:12 AM
My Name is Nobody
MSchu's Avatar
Default Re: 1978 civic 1200 rear engine right hand drive conversion(pics) (newby_j)
good stuff here
Old 08-31-2007, 03:07 PM
MotorMouth's Avatar
more pics coming soon. added some more flooring. bracing, mocked up the turbo i may use and some other things
Old 09-10-2007, 07:01 PM
MotorMouth's Avatar
bump to keep it goin until i get time to post more
Old 09-22-2007, 02:02 PM
MotorMouth's Avatar
ttt. sorry taking so long. but more has happened though
Old 12-16-2007, 10:07 AM
MotorMouth's Avatar
Old 12-16-2007, 10:16 AM
MotorMouth's Avatar
Old 12-16-2007, 11:04 PM
* B A N N E D *
[JDM]James's Avatar
This thing is sick bump for you!
Old 12-17-2007, 05:13 PM
Turbo EG4's Avatar
Location: Ghost riding my grandmamas whip YEP, Los Angeles Cali
Default Re: (cb07)
looks like a good project
Old 12-18-2007, 01:11 AM
bgangsta180's Avatar
all i can say is wow
Old 12-18-2007, 12:23 PM
desertwettback's Avatar
Default Re: (bgangsta180)
crazy, I knew this mexican that had a crazy custom flaired out version.
Old 12-18-2007, 12:51 PM
NW Classic Honda's Avatar
Default Re: (desertwettback)
That thing needs a raced out Mugen widebody conversion. The radiator scope is ugly and the rear wheels need attention but other than that its pretty crazy!
Modified by jdmda7 at 2:34 PM 12/18/2007
Old 12-18-2007, 01:30 PM
crazy, I knew this mexican that had a crazy custom flaired out version. Looked wild w/ a metal fake blower scoupe and homemade wing.
Cityblue
Honda Civic (2001 - 2005)
07-20-2017 12:04 AM
x275radial
Suspension & Brakes
02-20-2013 04:01 AM
ENeRg3Tic
04-19-2003 10:50 PM
Quick Reply: 1978 civic 1200 rear engine right hand drive conversion(pics)
