Whats the best way to have this seal well?
Old May 16, 2003 | 12:45 AM
blufke's Avatar
Default Whats the best way to have this seal well?
Should i put some nylon washers on it and just tighten it down alot? Any ideas on what to tighen it down to? its for the pan if anyone is still wondering.
Old May 16, 2003 | 01:52 AM
wHOAlly's Avatar
Default Re: Whats the best way to have this seal well? (blufke)
earls strato seals
Old May 16, 2003 | 03:10 AM
PWRVTEC's Avatar
I used special gaskets made by a local rubber shop, that are made to seal submerged in oil. So I have one on both sides they were small enough in the center that I had to thread the fitting through, and the are about 1" around.
To tighten I just cranked it down till I could turn it no more, and also used red locktite. No you may think that with it that tight that the gasket would be distorted, but thats the nice thing, the gasket is very hard yet soft....Its a weird material....
Old May 16, 2003 | 03:32 AM
Canuk_SiR's Avatar
Default Re: Whats the best way to have this seal well? (PWRVTEC)
you cound just dab on some high temp liquid gasket. I did on my fiting (its diff. then that) and no problems yet.
Old May 16, 2003 | 07:44 PM
Kutsuju_SLeePER's Avatar
Default Re: Whats the best way to have this seal well? (Canuk_SiR)
Or some Teflon Tape
Old May 16, 2003 | 08:27 PM
inspyral's Avatar
Default Re: Whats the best way to have this seal well? (Sp00n'd Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n'd Supra &raquo;</TD></TR><TR><TD CLASS="quote">earls strato seals</TD></TR></TABLE>
A little extra Permatex for some extra insurance isn't a bad idea, either
Old May 16, 2003 | 10:17 PM
blufke's Avatar
Default Re: Whats the best way to have this seal well? (inspyral)
what can i get that i dont have to order from somewhere to seal it?
Old May 16, 2003 | 10:18 PM
blufke's Avatar
Default Re: Whats the best way to have this seal well? (Kutsuju_SLeePER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kutsuju_SLeePER &raquo;</TD></TR><TR><TD CLASS="quote">Or some Teflon Tape </TD></TR></TABLE>
talking about sealing the fitting to the pan itself, not about the threads themselves letting oil through. and i used to live right by ramstein.
Old May 17, 2003 | 12:27 AM
Sonny's Avatar
That's what I used and so far, no leaks!
You can get them at --&gt; http://www.amstreetrod.com
To see how I installed mine, go here --&gt; http://www.muller.net/sonny/cr....html
Get good seals, man. If that thing leaks, it is pain in the *** to take apart and fix!
Sonny
Old May 17, 2003 | 05:47 AM
BoostedH23a1's Avatar
Default Re: Whats the best way to have this seal well? (Sonny)
i would braze it onto the oil pan but thats just me.. with my luck somehow that nut would manage to come off and tear up my motor
Old May 17, 2003 | 09:17 AM
Pritos's Avatar
New User
Those strato-seals are sweet. But I understand you'de like to get that on ASAP. What would I do?
Cut the hole in the oilpan to the smallest tolerance possible, then put a single tack weld on the fittings to the pan, then JBWELD THE SUCKER ON!
Old May 17, 2003 | 09:32 AM
SiRkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny
ditto
Old May 17, 2003 | 11:15 AM
Pritos's Avatar
New User
Default Re: Whats the best way to have this seal well? (SiRkid)
dang nice Writeup Sirkid. *applause*
Old May 17, 2003 | 11:53 AM
civictypenos's Avatar
Default Re: Whats the best way to have this seal well? (Pritos)
just make sure the hole is not too big,get it as close to the size of the fitting as possable,then put some rtc gasket maker on it(both sides) and tighten it up.it will hold with no probelms.the fittings them self,if tightened tight enough would hold hold it with out any thing on it.the oil pan is so thin that that fitting will compress and seal,just add the rtv for that extra security.
Old May 17, 2003 | 11:57 AM
boosted3g's Avatar
Default Re: Whats the best way to have this seal well? (civictypenos)
While you have it off just weld it.
xgenn786
Oct 27, 2005 04:41 AM
DualCamDan
Jul 26, 2005 04:19 AM
RACEPAK
Apr 16, 2005 05:38 AM
Jonathan_ED3
Jun 19, 2003 09:47 AM
slow90si
Aug 15, 2002 10:01 PM
