Whats the best way to have this seal well?
Should i put some nylon washers on it and just tighten it down alot? Any ideas on what to tighen it down to? its for the pan if anyone is still wondering.
Re: Whats the best way to have this seal well? (blufke)
I used special gaskets made by a local rubber shop, that are made to seal submerged in oil. So I have one on both sides they were small enough in the center that I had to thread the fitting through, and the are about 1" around.
To tighten I just cranked it down till I could turn it no more, and also used red locktite. No you may think that with it that tight that the gasket would be distorted, but thats the nice thing, the gasket is very hard yet soft....Its a weird material....
Re: Whats the best way to have this seal well? (PWRVTEC)
you cound just dab on some high temp liquid gasket. I did on my fiting (its diff. then that) and no problems yet.
Re: Whats the best way to have this seal well? (Sp00n'd Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n'd Supra »</TD></TR><TR><TD CLASS="quote">earls strato seals</TD></TR></TABLE>
A little extra Permatex for some extra insurance isn't a bad idea, either
Re: Whats the best way to have this seal well? (Kutsuju_SLeePER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kutsuju_SLeePER »</TD></TR><TR><TD CLASS="quote">Or some Teflon Tape </TD></TR></TABLE>
talking about sealing the fitting to the pan itself, not about the threads themselves letting oil through. and i used to live right by ramstein.
That's what I used and so far, no leaks!
You can get them at --> http://www.amstreetrod.com
To see how I installed mine, go here --> http://www.muller.net/sonny/cr....html
Get good seals, man. If that thing leaks, it is pain in the *** to take apart and fix!
Sonny
Sonny
Re: Whats the best way to have this seal well? (Sonny)
i would braze it onto the oil pan but thats just me.. with my luck somehow that nut would manage to come off and tear up my motor
New User
Those strato-seals are sweet. But I understand you'de like to get that on ASAP. What would I do?
Cut the hole in the oilpan to the smallest tolerance possible, then put a single tack weld on the fittings to the pan, then JBWELD THE SUCKER ON!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny »</TD></TR><TR><TD CLASS="quote">
Sonny
ditto
Sonny
ditto
Re: Whats the best way to have this seal well? (Pritos)
just make sure the hole is not too big,get it as close to the size of the fitting as possable,then put some rtc gasket maker on it(both sides) and tighten it up.it will hold with no probelms.the fittings them self,if tightened tight enough would hold hold it with out any thing on it.the oil pan is so thin that that fitting will compress and seal,just add the rtv for that extra security.
Jonathan_ED3
06-19-2003 09:47 AM
