emissions test??
I passed emissions in MD, I have a 2000 civic with custom turbo kit and all they did was a ECU test. no dyno at all, as long as you keep the stock ecu in, well they only do the just the ecu test on 96 and up cars. I didnt even unhook anything. they did no visual, just did a pressure test on the gas cap and ecu test.
heh heh i live in CT and for the time being theres no emissions checking at all. But as long as u have the stock exhaust with the cat or if u put it back on it should pass. you at least need the cat.
i took my car for emissions today and i failed... they said that my ecu has too many codes... anybody know how i can fix it?? will a missing link help?
2001integra drag3
2001integra drag3
big question is...will you pass smog in cal? I think if your tuned right and not running a humungus exhaust and running a cat....you'll have a chance
You had too many codes?? do you have any checkengine lights on? if u did you will fail no matter what. fix all the check engine light codes. and you should be ok.
on another note make sure once you get all the cels straight drive it for a week to make sure u get no more cels, if you have no cels bring it back in to get it tested.
Sagedom
Engine Management and Tuning
Feb 20, 2019 04:47 PM
MulletManRockStar
Oct 13, 2004 12:44 PM
hybrider
Apr 29, 2003 06:50 PM
