Indiglo guages in a 95 civic
Old May 14, 2003 | 05:39 PM
99fbpem1's Avatar
Default Indiglo guages in a 95 civic
I have a 95 civic and a set of indiglo guages and the crappy instructions tell me to hook the power wire for the indiglo guages to the head lights wire, can ne 1 help me with this? i can't find the headlight wire
Old May 14, 2003 | 05:56 PM
cash459's Avatar
Default Re: Indiglo guages in a 95 civic (95civicdx)
you should really hook it up to the parking lights wire, that way any time you turn on your lights, they will be on....the best way to check it, is to get one of those things that you can stab into the wire and check the current...it has a light and lights up when that wire is active (cant remember what its called)...thats what i did...
Old May 14, 2003 | 05:59 PM
99fbpem1's Avatar
Default Re: Indiglo guages in a 95 civic (cash459)
where is the parking lights wire at? easy acess? plz give me details
Old May 14, 2003 | 06:19 PM
99fbpem1's Avatar
help plz
Old May 14, 2003 | 07:09 PM
ExiledinIN's Avatar
https://honda-tech.com/zerothread?id=504117
You can download a Helms manual that should tell you where it will be located.
Old May 14, 2003 | 07:10 PM
AllMotorBrew's Avatar
if it is the same as the ek then pop out the dimmer switch and just put the black to black and find out with one is positive by turning on the headlights and puting the wire in there and if they glow you got it right
Old May 14, 2003 | 08:20 PM
IWearMyKswiss's Avatar
New User
Default Re: Indiglo guages in a 95 civic (nitrousFed97ek)
instead of your hunt for the actual wires,...why dont you just tap it into your fuse box,...use the parking lights fuse
mitchh29
31
Mar 30, 2013 12:13 PM
MightyHyman
12
Oct 2, 2012 05:31 PM
b18c1vtecdc2
May 29, 2009 10:29 AM
ScuderiaFerrari
24
Nov 8, 2004 07:41 PM
