GSR front subframe brace on 92-95s w/ P/S?
Old May 14, 2003 | 03:34 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default GSR front subframe brace on 92-95s w/ Power Steering?
Is this possible? It doesn't look like it...
The rack is totally in the way of me getting that bar in, nevermind bolting it down.
Pic without the bar
Here's a pic of the bar in question:
The other side works fine, but that doesn't do me much good.
Old May 14, 2003 | 03:37 PM
fowler!'s Avatar
Default Re: GSR front subframe brace on 92-95s w/ Power Steering? (SkyeC)
How much did you buy that bar for?
Old May 14, 2003 | 03:44 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: GSR front subframe brace on 92-95s w/ Power Steering? (fowler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fowler &raquo;</TD></TR><TR><TD CLASS="quote">How much did you buy that bar for?</TD></TR></TABLE>
ten dollars
Old May 14, 2003 | 05:08 PM
43MA's Avatar
i tried puttin it in without the motor
the bar can't clear the power steering rack
Old May 14, 2003 | 05:24 PM
rob d's Avatar
Default Re: GSR front subframe brace on 92-95s w/ Power Steering? (Steady)
I had no problems with mine. I have a 94 EX. Did you try both ways to put it on? Try fliping the bar. (right to left/left to right)
Old May 14, 2003 | 05:30 PM
kefka's Avatar
Default Re: GSR front subframe brace on 92-95s w/ Power Steering? (rob d)
you just have to relocate those hard lines you can once you do that...i have one in my si..
Old May 14, 2003 | 05:44 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: GSR front subframe brace on 92-95s w/ Power Steering? (eh neo)
Well, there's no way I'm going to be able to bolt it in with the steering rack in the way, in particular that big circular unit near the hard lines.
Just wanted to make sure I was trying to put it in the right spot.
Who wants a subframe brace? $10+s/h. PM me.
Old May 14, 2003 | 05:51 PM
rob d's Avatar
Did you even try to put it on? I should fit. If not, your subframe might be mest up. Take the bolts out and try it again. Its a tight fit.
Old May 14, 2003 | 06:09 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Like I said, the P/S rack is in the way and there is very little space around it so even IF I got it in there, there's no way my hands and a ratchet or a wrench can get in there to bolt it down.
It's not worth the hassle.
Old May 14, 2003 | 06:17 PM
yellow eg's Avatar
i want it
Old May 14, 2003 | 06:28 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: GSR front subframe brace on 92-95s w/ Power Steering? (yellow eg)
yellow eg is #3 on the list... quit PMing me about this thing, people...
Old May 14, 2003 | 06:41 PM
b19coupe's Avatar
I put that brace on my 95 EX coupe no problem. That was when I still had power steering. I still have the brace, but no P.S.
Old May 14, 2003 | 06:51 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: GSR front subframe brace on 92-95s w/ Power Steering? (b19coupe)
Oh well, I must be retarded then. Bar is sold because I'm a lazyass.
Old May 14, 2003 | 07:12 PM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">Oh well, I must be retarded then. Bar is sold because I'm a lazyass. </TD></TR></TABLE>
Oh well? That sucks! Didnt the gsr have power steering?
If you unbolt the lines and then put it underneath the lines
and bolt it all back together it should work. I have a few of
the eg6's tie bars if anyone is interested.
BOTAN01
Suspension & Brakes
13
Nov 28, 2007 06:12 AM
H.crx-si
35
Sep 5, 2004 03:30 PM
2 point 0
30
Apr 24, 2004 04:04 PM
Raocorp
14
Jan 10, 2003 05:48 AM
