Is a Benen cross member bar the same as a lower tie bar?
First off I know what a cross member is but does Benen sell a cross member brace or an upgraded cross member? Or is it the same as a lower tie bar?
the pic from Benen:
the pic from Benen:
Re: Is a Benen cross member bar the same as a lower tie bar? (maxim)
it mounts in you engine bay, directly in front of the steering column... get that bar and a front lower tie bar, and afront strut bar... your steering response will be 100%better
Re: Is a Benen cross member bar the same as a lower tie bar? (euclid)
Are there any pics of it installed? Are there any fitment issues with it whatsoever?
Re: Is a Benen cross member bar the same as a lower tie bar? (redman223)
Are there any fitment issues with it whatsoever?[/QUOTE]
i have a power steering rack and it was a really close fit, like 1mm... and i had to disconnect the mounting bracket for a p.s. hardline that uses the same hole in the chasis that the crossmember bar does. but im not having any problems w/ it after it was installed. its a pain in the *** to manuever the bar into where it is susposed to be mounted but i had the cusco front lower bar on already so that made it alittle tougher. just give yourself an hour, it'll definately fit, it just takes some patience b/c theres alot of **** in that area of the car.
no, it is not the same. It is an "upgraded cross member."
so then the original bar is removed and replace with the benen bar.....correct?
Re: Is a Benen cross member bar the same as a lower tie bar? (Raocorp)
[Modified by eg6si, 8:22 PM 1/9/2003]
OG triple OG
Re: Is a Benen cross member bar the same as a lower tie bar? (eg6si)
hmmm , are u tellin me i just found another bar i can stick somewhere????? tight tight!!! consider it ordered
Re: Is a Benen cross member bar the same as a lower tie bar? (TeamUntouchableRacing)
can the stock 94-01 integra cross member fit 92-95 hatch with a b series motor and stock motor?cuz it looks like the bar will hit the shift link age.
Re: Is a Benen cross member bar the same as a lower tie bar? (TEAM JSJ)
i think you guys got it all mixed up...
that pic is the one that goes to the back
its the bottom one
its the bottom one
Re: Is a Benen cross member bar the same as a lower tie bar? (JDMb18civic)
i thought that bar is called a strong bar?and the cross member go by the shift like age???
1993 lx civic sedan automatic
1993 si del sol
1993 civic si hatchback
its the bottom one
its the bottom one
its the bottom one
its the bottom one
eg6si: Are the integra bars beefie bars? Is one from an ITR better/thicker/stronger than one from a gs or gsr? or are they all the same?
TeamUntouchableRacing: check this out....don't know if you have one of these already but you seem to be "bar" crazy like me. Its called a C-pillar bar from J's racing.
here is a pic of it installed on an integra:
They can be purchased from jdmspecperf.com. Here is the direct link to their
page
http://www.jdmspecperf.com/products/...ts.asp?type=js
