Some Box Questions.
Old May 13, 2003 | 08:40 PM
akeldama's Avatar
Default Some Box Questions.
First off, when a company suggests a volume for a sealed box, say .6 cubic feet, does that value include the displacement of the sub or not? Also, what type/gauge wire to run from the voice coils to the terminal inside of the box?
Thanks.
Old May 13, 2003 | 08:53 PM
vteg's Avatar
New User
Default Re: Some Box Questions. (EJ1)
The enclosure volume is after subtracting sub displacement, and port displacement if applicable. The gauge of wire you want to run depends on what you have on hand 12-14 gauge should be fine.
Modified by vteg at 11:28 AM 5/14/2003
Old May 14, 2003 | 03:33 PM
akeldama's Avatar
Default Re: Some Box Questions. (vteg)
The sub's displacement is only .05 cubic feet so it will work our perfectly. Thanks for your help.
Old May 14, 2003 | 03:46 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">The enclosure volume is after subtracting sub displacement, and port displacement if applicable.</TD></TR></TABLE>
That's not NECESSARILY true...some manufacturers provide GROSS numbers. Those numbers have already taken the woofer volume into consideration, while NET numbers require you to take port and driver size into considerion.
Image Dynamics is one company who uses gross numbers on their data sheets, so like with most things, YMMV.
Regardless, on a sealed design most woofers won't be adversely affected by a +/-10% change in box volume.
Old May 14, 2003 | 04:02 PM
akeldama's Avatar
Default Re: Some Box Questions. (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">
Regardless, on a sealed design most woofers won't be adversely affected by a +/-10% change in box volume.</TD></TR></TABLE>
What a coincidence. The sub I have ordered is an Image Dynamics v3.
Old May 14, 2003 | 04:25 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
What a coincidence. The sub I have ordered is an Image Dynamics v3.</TD></TR></TABLE>
you sir are a good man...you will like it, just make sure the box is solid.
Worldsport
Audio / Security / Video
May 10, 2008 08:41 PM
j-spec_cc2
Jul 24, 2006 08:17 AM
JoshuaVTEC
Jan 23, 2006 09:33 AM
skrewdriver88
18
Jan 3, 2006 11:29 AM
