Speakers Cutting out......Help!
Like the Title says, i have a Si cd player in my hatch, and lately it has been cutting out when i am turning or if the car just barely hits the slightest bump it does the same thing. Now I know that it is not skipping just for the fact that it sounds like the speakers are phasing out and then they phase back in, It could be described as a blown speaker sound, I think that this could be cause in it but not sure. I hope that is enough detail if now I will give as much as possible.
Thanks
Thanks
if all the speakers are cutting out, you probably have a loose wire (power/gound) leading to the head unit.
If it's just one speaker, you have a problem with the wire leading to that speaker.
Check all the connections on the wires, make sure they are solid and that the insulation is intact on all of them.
I would agree, if they produce sound at any time, and then cut out, they are not blown. I would check the wire harness behind the head unit, if it is all of the speakers that are cutting out, the extra G's might cause it to be looser.
Cool guys, thanks for the Quick Response, that i kinda the direction that i was going in, as far as the loose wire area, but still thanks for the quick response.
Jose-aka-Pedro
Audio / Security / Video
May 15, 2006 11:20 AM
