What's a better block......B20z or B18b1????
Old May 12, 2003 | 11:18 AM
hmongdude's Avatar
Default What's a better block......B20z or B18b1????
I'm planning to go get a block down south in cali and I wanted to know from you guys what is a better block for my B16 head...... Can you guys give me any suggestion........thanks
Old May 12, 2003 | 11:19 AM
russian_racer's Avatar
Default Re: What's a better block......B20z or B18b1???? (hmongdude)
thats what I want to know too!!!
Old May 12, 2003 | 12:51 PM
illusive's Avatar
Default Re: What's a better block......B20z or B18b1???? (russian_racer)
I like the B20z personally.......loads of low end torque. Most your power is at low RPMs. And if you want to go vtec it works just like the B18b. CRVtec's own....haha
Only thing is when you go with a B20 you will have to change the intake manifold because it sits to high and use a B18b manifold
Old May 12, 2003 | 01:27 PM
Kaan's Avatar
Loved
Community Favorite
Default Re: What's a better block......B20z or B18b1???? (illusive)
read up with russian racers post.... i'm a B20 boy... cost a little more in the long run... but they rock hard core
Old May 12, 2003 | 01:34 PM
goforbroke's Avatar
MEAT PATTY
Default Re: What's a better block......B20z or B18b1???? (MMsportsRexSi)
I would say a b18b because its "kind of" built to rev to 7000-8000 rpm, or you can just sleeve it. The b20z are not built to rev to 8000 grand they have weak cylinder walls inside the block that is why alot of people sleeve them. I would rather go with a b18b because they are cheaper and you can always sleeve them in the long run. Even though they are alot of people who have b20 on this site who rev to 8000 every day without any problems. But its only a matter of time.
Old May 27, 2003 | 01:18 PM
Snail Tuning's Avatar
Default Re: What's a better block......B20z or B18b1???? (goforbroke)
the only differance between the 2 is the boar. the b20 and b18b are the same block just the b20 has a bigger boar giving it weaker sleaves. if your going to sleeve it do the b20 get better low end toq and u can easily get the hp by new intake manifold and other simple mods. plus u will have a 2.0leter wich is perfect for boost.
ActiveAero
Feb 9, 2003 09:39 AM
es four
Oct 29, 2002 09:50 AM
eddiecut
Aug 23, 2002 11:46 AM
lbz34
May 26, 2002 11:37 AM
KRiS1
Mar 29, 2002 06:08 AM
