problem with throttle cable... jrsc
Old May 12, 2003 | 09:29 AM
stormywaters's Avatar
Default problem with throttle cable... jrsc
anyone running the jrsc having problems with their throttle cable shearing?
i obviously do.
it seems that the throttle cable is rubbing against some part of the manifold, is this a common problem with the jrsc? my car only has 18,xxx miles and i don't want to have to replace a throttle cable every 15k miles.
anyone have any advice? i will try to post up pics.
Old May 12, 2003 | 10:05 AM
(__________)'s Avatar
Default Re: problem with throttle cable... jrsc (stormywaters)
Yes mine did the same thing, I went through one in about 15k. Use alot of grease it will help out some
Old May 12, 2003 | 10:16 AM
Default Re: problem with throttle cable... jrsc (steves98itr247)
thanks steve,
i just spoke to a tech at jackson racing and he told me exactly what you did, the pivit wheel tends to ceaze if it isn't greased properly.
heads up to all you dudes with the jrsc, keep the pivit wheel greased!
*edit for bad grammar
Modified by stormywaters at 3:35 PM 5/12/2003
Old May 12, 2003 | 11:35 AM
fredtoast's Avatar
I've had a jrsc for over a year and my throttle cable just broke. I have been concerned that the strain of supercharging would cause damage to my engine. However I would never have thought that my broken throttle cable could have been related to the jrsc. H-T RULES! Now I wonder if it had anything to do with my cracked exhaust manifold.
Old May 12, 2003 | 12:09 PM
Batoutahell's Avatar
Default Re: problem with throttle cable... jrsc (fredtoast)
My cable sheared to the point that only 2 wires were intact. I use lots of grease also.
Old May 12, 2003 | 01:14 PM
finally found a web host...
for those of you wondering what exactly i am talking about, here is a picture to illustrate:
the black thing under the cable is the pivit wheel.
Old May 12, 2003 | 01:32 PM
Spunkster's Avatar
Yeah they will eventually break, but new cables are only like $15 anyway so it's not too big of a deal.
If you really want to get fancy, you can swap in a GSR cable, but you will have to change the throttle cam to a GSR one and then attach the GSR cable stop.
In the end it's much cheaper and easier to just buy a new cable every once in a while.
Old May 12, 2003 | 05:47 PM
SamC's Avatar
Default Re: problem with throttle cable... jrsc (Batoutahell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell &raquo;</TD></TR><TR><TD CLASS="quote">My cable sheared to the point that only 2 wires were intact. I use lots of grease also.</TD></TR></TABLE>
is there any specific type of grease to use?
Old May 12, 2003 | 06:30 PM
Default Re: problem with throttle cable... jrsc (SamC)
I just use the same plain-jane synthetic hi-temp grease that I use for everything else (clutch, brakes, axles, etc.)
Old May 13, 2003 | 05:27 AM
fredtoast's Avatar
Default Re: problem with throttle cable... jrsc (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">Yeah they will eventually break, but new cables are only like $15 anyway so it's not too big of a deal. </TD></TR></TABLE>
It is a big deal if it strands you like it did me. Now that I know about this problem I'll keep an eye out and replace it BEFORE it breaks.
Old May 13, 2003 | 08:35 AM
SamC's Avatar
What happens when the cable breaks?
Is it hard to replace?
Old May 13, 2003 | 09:00 AM
reefer_bob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SamC &raquo;</TD></TR><TR><TD CLASS="quote">What happens when the cable breaks??</TD></TR></TABLE>
Uh.... your motor idles?
Hmmmmm..... yep!
Corksil
Mar 29, 2013 07:57 PM
undagroundrican
Aug 12, 2007 07:02 AM
econorocket
Mar 14, 2007 03:32 PM
SPOOLINmatt
Mar 12, 2004 09:50 AM
steves98tr247
Jul 1, 2002 10:12 AM
