Turbo H22a: Clutch setup?
I am a turbo noob, so help me out. I have a H22a and I plan on using an Accord tranny. I still need a clutch and flywheel for the set-up and I want to run boost, maybe around 5-10psi. I here ACT's are good. I'm also on a tight budget so low prices are nice.
1. Do I need a specific Flywheel, or will a stock OEM work fine?
2. What kind of ACT clutch/(flywheel if needed) should I go for?
3. How much will it run?
Thanks
Thanks
i have the same setup in my car right now..i am using the stock flywheels
my clutch is a 6 puck unsprung disc with extreme pressure plate
i think i got it for around 250...from act
it has been in my car since sep.2001
its holding up pretty good
ACT xtreme pressure plate and organic street disk. I just picked up that combo for mine and it holds like crazy and has a smooth engagement. Also my turbo is going on my h22 next weekend hopefully, so I'll be able to give you some more info then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d98clturbo »</TD></TR><TR><TD CLASS="quote">hey DLB1994
i noticed that you dynoed 337 with your h23... what do you have(compresion, cams?)</TD></TR></TABLE>
10.2:1 comp and stock cams
JDM turbo DC
Oct 19, 2006 09:21 AM
bubblehead
May 31, 2006 02:39 AM
