code 22, how to fix????
Old Jul 7, 2001 | 05:01 PM
prjctCIVIC's Avatar
Default code 22, how to fix????
can someone tell me how to fix the code 22 (vtec malfunction)..what can be the cause of this???? BTW: i have a 97 gsr motor in a 92 civic si....thanks
Old Jul 7, 2001 | 06:32 PM
raene's Avatar
Default Re: code 22, how to fix???? (prjctCIVIC)
When I got a VTEC solenoid code, it was because the wire had pulled out of the bottom of the VTEC solenoid. Just check all the connections over, reset the ECU, and try again. If it comes on again first try plugging in a different ECU to see if it's a computer problem.
Old Jul 7, 2001 | 07:03 PM
RTEK's Avatar
New User
you may have crossed the VTEC solenoid wire and the VTEC oil pressure swith wire
trace it back to the ECM
just look it over
TECH TIP
apply +12V on the green wire of the VTEC solenoid; if the solenoid clicks, you have a signal (electrical) problem possibly open/short circuit
hope this helps good luck
Old Jul 7, 2001 | 09:50 PM
Blown90hatcH's Avatar
Default Re: code 22, how to fix???? (RTEK)
22 is the vtec pressure switch....pull the plug off and check for continuity between the pins of the switch....if none = bad switch....if some= bad wiring
Jason
fryguy190
Mar 23, 2008 07:27 PM
racereaper7
Aug 14, 2007 08:56 AM
Mentat Ghola
May 15, 2003 10:15 PM
Hondasaurs
May 5, 2003 03:00 PM
pelotudo
Jan 30, 2002 11:43 AM
