knockin high rpms when clutch is all they way end help
Guest
Posts: n/a
well i thought my motor was bad! but i found out tonight i put my car clutch all the way end an put it in first! the car started jerkin i pulled off the dust cover i though it would be the fly wheel maken that sound but it all looks good! im going to pull the old pan off seen i thnk the motor is fine! it just maken a lound *** knockin noise i cant find out what it is it starts about 3 thow rpm what yall think it is????
I know a guy on here from a town 40 minutes away had the same problem. Where's it comming from? (Take a screw driver, put your ear on the handle, and put the tip against your engine. Move around until it's the loudest, and list where that spot is). I believe it was on the head by the distributor. Honda replaced his distributor thinking it was that or the bearing on it... but I guess it wasn't. If you figure out what it is let us know.
Yeah mine did the same thing... it ended up that my timing belt was loose and in there makin noise. I tired to set my ignition timing and it was jumpin all over the place... so that made me wonder... and it ended up that that's what it was. It was weird cuz it was making a knocking noise, that and I had a valve that worked it's way really loose and it was makin a lot of racket too.
I'm ashamed to be from the south sometimes.
Since none of us can really understand what you're trying to say....
OK, my first guess is a bearing. It coming from the bottom end and towards the flywheel side.
Pull the oil pan, oil pickup and get it out of the way. Grab the bottom of the rod on that end nearest the flywheel and see if it feels loose on the crank. Check all the rod ends the same way.
a ticking or clacking will be valves... a *knocking* generally means a bearing.
If you could maybe seriously try to use a little better typing skills and describe where exactly the sound is comeing from, and in more detail about what it sounds like, we can better help you.
headrec*
Transmission & Drivetrain
Aug 29, 2008 08:49 PM
Grammar Police.
