vtec popping in and pop at high rpms!!!!!!!!!!!!!!!!!!!!!!!!
Old May 10, 2003 | 11:27 AM
Da Integra's Avatar
Default vtec popping in and pop at high rpms!!!!!!!!!!!!!!!!!!!!!!!!
hi guys its me agian, still have got to the track but did a leak down test all ok but now i have aouther problem. my vtec is popping in and out of vtec at high rpms!!! my oil is good and water level is good also what do you guys think??
Old May 10, 2003 | 11:32 AM
P1mpSlap's Avatar
what did your leak down test say?
Old May 10, 2003 | 12:19 PM
Chris's Avatar
Default Re: (P1mpSlap)
what RPM?
I got $100 that says you are hitting your rev limiter.
Old May 10, 2003 | 12:41 PM
Da Integra's Avatar
the shop who did it didn't give me much details all he said that the motor is in great shape and the rings have little blow by thats all. and the rpms that i was in are around 6000 rpm and i'm not hitting the rev limiter red lines at 9200 rpms i shift at 8500 rpms
Old May 10, 2003 | 12:57 PM
Chris's Avatar
Default Re: (Da Integra)
another $100 gone
Old May 10, 2003 | 06:05 PM
integraL's Avatar
Default Re: (Chris)
yeah i dont hear that much of a difference either...i hear its cuz mine is stock. will an intake improve the sound of VTEC?
Old May 11, 2003 | 05:51 AM
MooreBoost's Avatar
Default Re: (2001gsRguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001gsRguy &raquo;</TD></TR><TR><TD CLASS="quote"> will an intake improve the sound of VTEC?</TD></TR></TABLE>
Yup.
Old May 11, 2003 | 05:53 AM
Regular Series's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da Integra &raquo;</TD></TR><TR><TD CLASS="quote">the shop who did it didn't give me much details all he said that the motor is in great shape and the rings have little blow by thats all. and the rpms that i was in are around 6000 rpm and i'm not hitting the rev limiter red lines at 9200 rpms i shift at 8500 rpms</TD></TR></TABLE>
9200 RPM? What's your setup?
Old May 11, 2003 | 08:40 AM
VTECorona's Avatar
Default Re: (Beelzebozo)
Low on oil?
Old May 11, 2003 | 10:02 AM
viCeVerSa's Avatar
Default Re: (97RedTegGSR)
your making power at 9200? ..... .................whats your setup?
Old May 11, 2003 | 05:27 PM
SearchBeforeUPost!'s Avatar
Default Re: (viCeVerSa)
sounds like bad vtec solenoid
Old May 11, 2003 | 06:13 PM
MooreBoost's Avatar
Default Re: (Bda91acc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bda91acc &raquo;</TD></TR><TR><TD CLASS="quote">sounds like bad vtec solenoid</TD></TR></TABLE>
I doubt it, if it was faulty I doubt that it V-tec would ever hit. I would check the sensors first. Any CEL codes?
gmoore
Old May 11, 2003 | 07:35 PM
Da Integra's Avatar
well i have no check eng. codes at all and my mods are cam gears,cat back exhaust and intake,fpr,free flow cat,skunk2 racing chip,act extrame 6 puck clutch. i also have good oil level. The reason for 9200 rpms is when i have cams and type r intake man. i can have the extra rpms to make power.
Old May 12, 2003 | 04:01 AM
i actually meant to add that it could be a loose connection or bad wiring to the vtec solenoid.
Old May 12, 2003 | 09:34 AM
romeo619romeo's Avatar
connections is overheating maybe....
Old May 12, 2003 | 02:06 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da Integra &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 racing chip</TD></TR></TABLE>
Slim chance thats your problem. Do you have the old ECU? Try putting it back in if you do.
gmoore
Old May 12, 2003 | 07:34 PM
darrinbrewer's Avatar
Default Re: (tegunderpressure)
on my gsr stock ecu and vtec setings:fine...use my skunk2 ecu with 5700 vtec..it stutters off and on sometimes when slowly climbing into vtec(3rd and 4th gear)...i'm thinking it's oil pressure..oil pump going out eventually..i've been reading up on this cuz i want NO MORE STUTTERING in VTEC! n-e-1 else got any ideas?
Old May 12, 2003 | 07:52 PM
Vtec integra's Avatar
Default Re: vtec popping in and pop at high rpms!!!!!!!!!!!!!!!!!!!!!!!! (Da Integra)
check your oil levels. thats the frst thing if you dont have enough oil it will do that
Old May 13, 2003 | 06:34 AM
jgold47's Avatar
vtec solenoid could be going bad, its a little plunger and if its not got enough pressure behind it in theroy it could be beign pushed back.....
Old May 13, 2003 | 06:47 AM
Agent#ONE's Avatar
Default Re: (jgold47)
vtec ground
cold motor
no oil pressure
Old May 13, 2003 | 04:16 PM
Da Integra's Avatar
well now i got a code 22 vtec pressure switch today how much does it cost for one ???? man this sucks
Old May 14, 2003 | 05:13 PM
Spoodge's Avatar
From: Slut City aka San Diego, Ca, United State Of King
take off ur v-tec solinoid and check in side..there is a little filter in there clean it out...
William5353
May 8, 2016 05:47 AM
redline09
Jan 23, 2010 06:11 PM
illuzi0nz
Oct 29, 2006 02:00 AM
DocV
Jan 10, 2003 06:58 PM
yellowbuffalo
May 2, 2002 07:31 PM
