Clutch/Tranny Question
Old May 9, 2003 | 08:12 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Clutch/Tranny Question
I have two problems:
1) It's hard to get into first gear. I need to use some force. I find it easier to put it in 2nd then up to first.
2) When in first gear and clutch is not engaged yet (foot is still on clutch pedal), sometimes the engine jerks like I'm in gear, pushes the car like I'm in gear then stalls...but clutch has no engaged, clutch pedal is pressed all the way down.
Please help, TIA.
Old May 10, 2003 | 02:55 PM
GapxGuy's Avatar
Default Re: Clutch/Tranny Question (GapxGuy)
Old May 10, 2003 | 03:02 PM
mugensport9's Avatar
i think thats a bad clutch and not the tranny
Old May 10, 2003 | 03:04 PM
GapxGuy's Avatar
Default Re: Clutch/Tranny Question (mugensport9)
It's a brand new Clutch Specialities 6 puck.
Old May 10, 2003 | 04:21 PM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 &raquo;</TD></TR><TR><TD CLASS="quote">i think thats a bad clutch and not the tranny</TD></TR></TABLE>
that's what i was gonna say but....maybe synchros?
Old May 10, 2003 | 05:53 PM
ITR#132's Avatar
Check your fluid level and Master cylinder for leaking.
Def sound clutch related especially if the pedal is all the way to the floor.
Old May 10, 2003 | 06:59 PM
GapxGuy's Avatar
Default Re: Clutch/Tranny Question (ITR#132)
So you guys think it's the clutch? I don't understand, it's a brandnew clutch and I just dropped in my motor this month, so all I fluids should be full. What about getting in first gear? It's hard to get into first too.
Old May 10, 2003 | 07:40 PM
jeiden's Avatar
it's got to be your clutch, it's not disengaging completely
Old May 10, 2003 | 07:51 PM
GapxGuy's Avatar
Default Re: (jeiden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeiden &raquo;</TD></TR><TR><TD CLASS="quote">it's got to be your clutch, it's not disengaging completely</TD></TR></TABLE>
Half the time it does this, not always. Can this be fixed or am I screwed until I replace a new clutch?
Old May 11, 2003 | 11:04 AM
NeoGSR's Avatar
Default Re: (GapxGuy)
try checking/bleeding the slave cylinder
Old May 11, 2003 | 06:46 PM
Eziekel's Avatar
well i got the same problem as you . but my car didnt wanna get into gear at all.. so then some guy that i met at a kragen store he said something was wrong saying air was getting into the tranny. some other people say that i didnt have my cover where my tranny is so thats why air get into there. and then i didnt have oil in my tranny either. my tranny gots 151,xxxx miles and i dont know what do use. people told me to use 10x30 motor oil. what do i do? anybody?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy &raquo;</TD></TR><TR><TD CLASS="quote">I have two problems:
Please help, TIA.</TD></TR></TABLE>
Old May 11, 2003 | 06:47 PM
Eziekel's Avatar
Default Re: (NeoGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR &raquo;</TD></TR><TR><TD CLASS="quote">try checking/bleeding the slave cylinder</TD></TR></TABLE>i think thats what was wrong with mines..
Old May 11, 2003 | 07:28 PM
GapxGuy's Avatar
Default Re: Clutch/Tranny Question (Kunfusion209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kunfusion209 &raquo;</TD></TR><TR><TD CLASS="quote">well i got the same problem as you . but my car didnt wanna get into gear at all.. so then some guy that i met at a kragen store he said something was wrong saying air was getting into the tranny. some other people say that i didnt have my cover where my tranny is so thats why air get into there. and then i didnt have oil in my tranny either. my tranny gots 151,xxxx miles and i dont know what do use. people told me to use 10x30 motor oil. what do i do? anybody?</TD></TR></TABLE>
Interesting...I haven't put on the cover for my tranny either. You're talking about the rubber boot for the lever fork right?
Old May 11, 2003 | 07:47 PM
Mohudsolo's Avatar
If the rubber boot over the release arm or the cover plate on the bottom of the bell housing are missing, they can let road crud get into the clutch area. The throwout bearing has to slide smoothly on the transmission input shaft area for the clutch to work properly. Failure to clean and grease the part the bearing slides on or replace the throwout bearing are common causes of poor clutch release on all cars. Degraded fluid or air in the clutch hydraulics will also cause the problem, try pumping the clutch pedal a few times and see if that helps, if it does then the fluid should be bled out just like bleeding brakes. The pushrod that connects the clutch pedal to the master cylinder is adjustable. The shop manual gives an adjustment procedure, give that a try too.
Old May 11, 2003 | 08:20 PM
GapxGuy's Avatar
Default Re: Clutch/Tranny Question (Mohudsolo)
I'm missing #5. I can pump the clutch pedal 2-3 times and it's still hard to get into first gear. It's much easier going into 2nd then into first.
mfisher1987
Transmission & Drivetrain
Feb 8, 2015 05:58 PM
CleanGSRek9
Jun 22, 2010 08:41 AM
antoneexx
Apr 6, 2007 01:50 PM
rriicckk787
May 10, 2005 05:13 PM
1FastCoupe
Apr 12, 2005 08:51 AM
