Clutch squeek
Old May 9, 2003 | 10:04 AM
cjohnson_2's Avatar
Default Clutch squeek
I have been experienceing some problems with my clutch lately but only after it rains. It is a extremly loud squeeking noise when i push the clutch pedal. This goes on for about 25 min what im guessing is the time it takes for it to dry out. after that its normal. It engages just fine and everything elese just noisy as hell. Anyone have any suggestions? It sounds to be comming from behind the rubber boot or possibly the slave cyl. itself?
Old May 9, 2003 | 10:35 AM
ebelp's Avatar
Default Re: Clutch squeek (cjohnson_2)
Check the inside of the car where the clutch goes through the firewall. If you see brake fluid leakage, you need to replace your clutch master cylinder.
Old May 9, 2003 | 01:15 PM
cjohnson_2's Avatar
Default Re: Clutch squeek (ebelp)
Ive already checked that. Any other ideas?
Old May 9, 2003 | 01:32 PM
gumbybum's Avatar
ya if it is a hydro tranny then it is were the slave cylinder hits the little lever that engages the throw out bearing. the exact place of the squeak id the little ball-peen and the little bowl that it sets in. just pull back that rubber boot and put some high temp grease in there that should do the trick..hope that this helped mang
Old May 9, 2003 | 02:31 PM
976's Avatar
976
New User
Default Re: Clutch squeek (gumbybum)
Bleed your clutch system before you replace anything.
Might just need a good flush...
cesar_civic_eg
May 1, 2007 03:07 PM
K-Spec
Sep 26, 2006 11:30 PM
RiCE On IcE 2
Jun 22, 2005 07:10 PM
PatrickGSR94
Aug 8, 2002 04:16 AM
sa21199
Aug 22, 2001 10:37 PM
