distributer problem?
Old May 9, 2003 | 09:41 AM
ogwutang's Avatar
Default distributer problem?
would a rough idle and backfiring be caused by a bad distributer? the timing is set to tdc, the plugs and wires are fine, the ignition coil resistance checks out fine, and the cap is new. the rotor looks fine but will buy a new one. any suggestions?
Old May 9, 2003 | 10:12 AM
ebelp's Avatar
Default Re: distributer problem? (ogwutang)
Sounds like you're running too rich or too lean?
Old May 9, 2003 | 11:38 AM
untitled's Avatar
Default Re: distributer problem? (ebelp)
check fuel system. do you hve any CEL's
Old May 9, 2003 | 12:11 PM
ogwutang's Avatar
Default Re: distributer problem? (88crx91integra)
every once in a while it says 74 which is #4 misfire, but i have a d16y7 that i had just swapped in and when i tried to start it up, it just had a very low idle and backfires like a madman. i've checked the resistance on the coil and checked the ignition control module, but they are good. i can't drive it like it is because it won't stay running
LST2
Jul 28, 2008 06:05 PM
dvp95
Aug 20, 2003 11:10 AM
NightHawk
16
Apr 16, 2003 05:52 PM
MintFlavored
Nov 11, 2002 12:28 PM
Big James
Jul 13, 2001 01:55 AM
