Header Wrap worth it?...DC 4-2-1 CC
Old May 8, 2003 | 06:56 PM
H23A1LUDE's Avatar
Default Header Wrap worth it?...DC 4-2-1 CC
Is it worth it to wrap my new DC SPort 4-2-1 header with exhaust wrap? Header wrap is supposedly better than ceramic coated header, reducing under hood temperature by 70%. The header wrap keeps the heat in the header allowing for hotter exhaust gases to flow through the exhaust system. So, even though I have a CC header, should I wrap it(I don't care about the engine not looking as good) or should I just keep it unwrapped? If it was wrapped...guys would wonder what was under it...hmm
Old May 8, 2003 | 07:04 PM
auto-gs-king's Avatar
Default Re: Header Wrap worth it?...DC 4-2-1 CC (H23A1LUDE)
Don't do it unless you plan on replacing a cracked header.
Old May 8, 2003 | 07:05 PM
Cottonwoodz's Avatar
Ceramic coated header+exhaust wrap=Cracked header...
Old May 8, 2003 | 07:08 PM
LudeyKrus's Avatar
so what kind of header can be wrapped safely? What makes a CC'd header crack when wrapped?
Old May 8, 2003 | 07:11 PM
H23A1LUDE's Avatar
Default Re: Header Wrap worth it?...DC 4-2-1 CC (LudeyKrus)
Damn it!...so, if it's too insulated it will crack? I'm guessing it's because the gases would be too hot inside the header and there needs to be some heat leaving the header.
Old May 8, 2003 | 07:33 PM
kb58's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">so what kind of header can be wrapped safely? What makes a CC'd header crack when wrapped?</TD></TR></TABLE>
Well take this for what it's worth. Where I work we use Inconel headers... when wrapped they end up cracking. Inconel is the best stuff you can use, period. I also work with ex-factory race car mechanics. They say, "wrapping = cracking." They suggest a stainless steel shrould. You have to allow air to circulate around the tubes.
Old May 8, 2003 | 07:49 PM
PoweredByPrelude's Avatar
how bout this wrap the header but with some space between each wrap...am i just a crazy thinker or a genieus?
Old May 8, 2003 | 07:54 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: (PoweredByPrelude)
a friend's wrapped dc cc headers has lasted more than a year already. he wrapped it because he accidentally sprayed some **** that took the cc from the header which caused the engine bay to get incredibly hot. so he wrapped it, and it's been fine ever since. not to mention a slight improvement from "CC-stripped" to wrapped.
Old May 11, 2003 | 10:40 AM
ophdehEEzY
Guest
Posts: n/a
Default Re: (ophdeheezy)
Old May 11, 2003 | 03:13 PM
SILVER LUDE's Avatar
I have my DC CC header wrapper for almost 2 years. And my car is a daily driver. I have about 32K on the car. I driver in summer winter rain or shine or snow and i havent noticed anything wrong with it. No cracks yet. but who knows what the future will hold.
If anything there is always room for improvement.... SMSP
Old May 11, 2003 | 03:15 PM
ophdehEEzY
Guest
Posts: n/a
Default Re:
so, what is up with all these claims that CC headers will crack??
Old May 11, 2003 | 07:05 PM
Default Re: Re: (ophdeheezy)
Well first of all wouldn't a full race motor have quite a bit more heat flowing through the headers. I could probally see a turbo'd manifold cracking if it were wrapped more heat thier i'm assuming also. Course i could always be wrong here
Old May 12, 2003 | 08:17 AM
flyrod's Avatar
Default Re: Re: (PoweredByPrelude)
I've had my stainless DC wrapped since I got it almost 6 years ago. My car is mainly a daily driver, but I've done several long road trips, many autoXes, and several open track days. No problems. Maybe the mild steel ones are cracking, but mine hasn't.
Old May 12, 2003 | 02:44 PM
optikal_blitz's Avatar
the reason why they crack is because of the fact that the ceramic material that the header is constructed of is designed to dissipate heat. when wrapping the header you dont allow the ceramic material to do its job..the heat stays in, and over stresses the piping to the point of expansion..ie. cracking.
Old Aug 24, 2003 | 10:29 PM
showgunz's Avatar
Default Re: (NatakuBlitz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatakuBlitz &raquo;</TD></TR><TR><TD CLASS="quote">the reason why they crack is because of the fact that the ceramic material that the header is constructed of is designed to dissipate heat. when wrapping the header you dont allow the ceramic material to do its job..the heat stays in, and over stresses the piping to the point of expansion..ie. cracking.</TD></TR></TABLE>
No, ceramic coating is to keep the heat IN, not out. It's an insulating material and if you ever touch a plate or a cup, it doesn't get hot as easily as metal because they're made of ceramic. I think the possible moisture that forms between the wrap and the header can cause corrosion and/or cracking. But I doubt that the whole header cracks because of the wrap, probably just the ceramic coating. To crack a header, you'll have to hit it pretty hard or go through other extremes.
Old Aug 24, 2003 | 11:53 PM
Elkins911's Avatar
Default Re: (showgunz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by showgunz &raquo;</TD></TR><TR><TD CLASS="quote">
No, ceramic coating is to keep the heat IN, not out. It's an insulating material and if you ever touch a plate or a cup, it doesn't get hot as easily as metal because they're made of ceramic. I think the possible moisture that forms between the wrap and the header can cause corrosion and/or cracking. But I doubt that the whole header cracks because of the wrap, probably just the ceramic coating. To crack a header, you'll have to hit it pretty hard or go through other extremes .</TD></TR></TABLE>
i agree.... i dont understand why the header would crack. there is no evidence that it will... its all he said she said at this point. of course, everyone knows someones whos had this happen, but what happend? what was the set-up? if the wrap causes cracking then why is it even still being used?
Old Aug 27, 2003 | 12:54 AM
Gerhard_001's Avatar
When you wrap a CC header your exhaust gas is to hot. Cermaic coating keeps the heat out of the engine bay and in the header, where it benefits by heating the exhaust enough to make a beneficial difference. By wrapping the CC header you can damage the cat and not to mention damage your header. Just like an engine if it runs to hot you detonate and shorten the life of the engine.
Old Aug 27, 2003 | 11:25 AM
Default Re: Header Wrap worth it?...DC 4-2-1 CC (9SpreludeH8)
back from the dead...lol
Old Aug 29, 2003 | 04:13 PM
LudeyKrus's Avatar
So would it still be a "bad" idea if the wrap were used on a mild steel header?
Bigjussin
Sep 16, 2004 03:37 AM
ImporttRacerr555
Nov 25, 2003 02:13 PM
jond
Aug 18, 2002 02:13 PM
5-SpeedFreak
18
Jan 25, 2002 09:44 AM
