Question on the idle adjustment
Old May 8, 2003 | 03:35 PM
Bondcivic007's Avatar
Default Question on the idle adjustment
I cleaned the throttle body on a D16Y8 engine, changed the seal, and I tried to adjust the idle but it's too high. Even when the screw is completely in, it's at 1000 RPM. If I turn the other way it goes higher. Any idea what may be wrong?
Old May 9, 2003 | 12:18 PM
tpr's Avatar
tpr
Default Re: Question on the idle adjustment (Bondcivic007)
Vacuum leak. Check all the vacuum hoses and the throttlebody gasket. Spray carb cleaner arounf the TB and intake vacuum hoses the idle will change when you spray the leaking hose or gasket.
jmpassey
Jun 7, 2018 02:34 PM
Excusetoboost
Sep 1, 2011 07:40 PM
95dc2teg
Sep 11, 2007 05:49 PM
go2sleep
Jun 27, 2006 01:36 PM
socki18
Apr 7, 2005 05:43 AM
