simple question, dont know the answer
Old May 8, 2003 | 01:38 PM
highbrid's Avatar
Default simple question, dont know the answer
is the 4wd on the crv controlled through the ecu or is it seperate? My buddy is thinking about throwing a vtec head on his wife's crv, but we dont know if the 4wd is seperate from the ecu or if we can just run a p28 or p72
thanks for the input
Old May 8, 2003 | 03:58 PM
Perfectionist's Avatar
Default Re: simple question, dont know the answer (highbrid)
The real time 4WD is controled via a viscuous coupling between the differentials. I'ts completely mechanical and is not controled in any way by the ECU.
Old May 8, 2003 | 04:54 PM
Chiovnidca's Avatar
Default Re: simple question, dont know the answer (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">The real time 4WD is controled via a viscuous coupling between the differentials. I'ts completely mechanical and is not controled in any way by the ECU.</TD></TR></TABLE>
I thought they used a dual pump setup. Either way there is no ECU control.
haroldthefly91crx
Dec 17, 2006 01:08 PM
memorybox
Nov 28, 2006 07:58 PM
tico
Oct 9, 2006 05:19 PM
hondaturtle
Mar 21, 2005 10:59 AM
Trevor
10
May 15, 2004 05:41 PM
