do i have to change my valve springs when installing new cams?
Old May 8, 2003 | 07:19 AM
CRX A4's Avatar
Default do i have to change my valve springs when installing new cams?
while i was changing my head gasket, i noticed that I think i have automatic cams, i am not 100% sure but it looked like my intake springs were not doubled up ( not sure, but they were green)
But my question is, If i get aftermarket cams such as either Skunk2 stage 1 cams or CTR cams, will i need to change my valve springs? or will i be able to get away with using the stock ones?
Old May 8, 2003 | 07:33 AM
slowpokesi's Avatar
Default Re: do i have to change my valve springs when installing new cams? (CRX A4)
you will be fine as long as your not reving past 8200
Old May 8, 2003 | 08:47 AM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Never hurts to change valve springs on a 13 year old motor that you are putting higher lift cams in...
ITRs are cheap and drop right in, and you can rev to 8500 all day long and not worry about snapping anything.
-Todd
Old May 8, 2003 | 09:22 AM
CRX A4's Avatar
Default Re: do i have to change my valve springs when installing new cams? (Count Blah)
do i have to pull my head off again to change my springs? i just changed the headgasket and really don't feel like puling the head off again
Old May 8, 2003 | 09:27 AM
EF_LSVtec's Avatar
yes, you do have to take the head off again...unless you have a special tool for it. Dont really know what its called but I've seen it being sold at an engine builders show...Really expensive too.
Old May 8, 2003 | 09:40 AM
CRX A4's Avatar
Default Re: do i have to change my valve springs when installing new cams? (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">you will be fine as long as your not reving past 8200</TD></TR></TABLE>
is this even with the automatic valve springs?
Old May 8, 2003 | 09:57 AM
Malgerus's Avatar
I'm pretty sure that the B16 autos have weaker valve springs. I would recommend changing them.
Old May 8, 2003 | 02:05 PM
roadawg's Avatar
Default Re: do i have to change my valve springs when installing new cams? (Mr. S)
Please fill me in with what you are talking about when you are referring to automatic valve springs and b16 auto's.
Old May 11, 2003 | 06:27 PM
CRX A4's Avatar
Default Re: do i have to change my valve springs when installing new cams? (slownlow)
the automatic motor only has one spring per valve on the intake side, the manual has a spring inside of the outer spring
Old May 11, 2003 | 06:34 PM
MADEINIRAQ's Avatar
mine had green outer springs.. with inners.. dont remember the color.. and brown exhaust springs, no inner.
I'm using portflow inners, ITR intake outers, and moved my stock intakes to the exhaust.
oh yeah.. 2000 ITR cams.
I would suggest upgrading springs no matter what.. because they are higher lift cams and your springs are OLD.
search for valve spring threads and read up.. good luck
Old May 11, 2003 | 10:52 PM
mr. wu's Avatar
Default Re: do i have to change my valve springs when installing new cams? (madeiniraq)
you don't need to take you head off just take your spark plug out and feed a piece of rope into the cylinders then lightly crank the piston against the valves so they dont drop when you pull the springs off. then put the new springs in. when i put mine in iused a flat head screwdriver, it was kind of trickey at first but i soon got the hang of it. just take the screw driver and push real hard on one side of the retainer until one of the little clips that hold the spring on the valve clicks in. it should hold its self there until you get the second clip in and your good to go.
potatointegra01
Jan 22, 2015 03:36 PM
b18 hatch mike
Jul 8, 2007 11:56 AM
shythappenz
Jun 29, 2004 06:11 PM
CRXSleeper
Sep 9, 2002 10:47 PM
sa21199
Feb 25, 2002 05:46 AM
