cams?
Old Jun 29, 2004 | 09:32 AM
shythappenz's Avatar
Default cams?
i have a 93 da i dont have any internals at the moment but i was wondering would anything happen if i put aftermarket cams in without changing the springs rockerarms ext...
Old Jun 29, 2004 | 05:35 PM
poetikrime's Avatar
Default Re: cams? (shythappenz)
bump
Old Jun 29, 2004 | 05:38 PM
Sack Master's Avatar
Default Re: cams? (tunerpadDOTcom)
The car won't run without any internals. To answer your question about the cams though. Some may only require stock springs and retainers, but you should get new ones anyways. It's always a great idea to have new springs when you put in new cams. Just get the ones that match your cams and you'll be fine. If you don't change them you could get valve float, coil bind and maybe some other harmful things could happen. Broken retainer blah blah blah
Old Jun 29, 2004 | 05:56 PM
Malice's Avatar
New User
there are cams u can use without changing the springs and stuff(ex. for vtec cars- skunk2 stage 1's, ITR). just dont change the redline setting
Old Jun 29, 2004 | 06:11 PM
b18c1995's Avatar
Default Re: cams? (Malice)
if the lift is high enough you will bind the springs and slap a piston against a valve.
potatointegra01
Jan 22, 2015 03:36 PM
b18 hatch mike
Jul 8, 2007 11:56 AM
eg-ed
Aug 21, 2006 12:12 AM
senselessviet
Jan 12, 2005 08:19 PM
