B heads
Old May 8, 2003 | 06:49 AM
jdhealy's Avatar
Default B heads
ok i was wondering whats the difference between
B18C1
B18C5
B16 ect but any way whats the difference between them if they were bare is the C5 still best or not looking and gettin another head to P&P and then build just wondering if i should still the C5 or find a cheaper one so witch one is best for a stock one befor P&P
thanks
Old May 8, 2003 | 07:33 AM
dfoxengr's Avatar
Default Re: B heads (jdhealy)
search this was covered the other day
Old May 8, 2003 | 07:39 AM
NSX Bob's Avatar
New User
The b18c1 v. b18c5 difference is in design, cams, valve springs, etc. b16a head is the same design as b18c5, but has different LMA's, cams, springs, etc. (not to mention the light P&P job on the b18c5).
Old May 8, 2003 | 08:00 AM
evolve's Avatar
From what I understand the B16B has the best flowbench numbers of the three, and the B16B intake cam is abit more aggressive. Can anyone confirm this?
Old May 8, 2003 | 09:14 AM
NSX Bob's Avatar
New User
Default Re: B heads (evolve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evolve &raquo;</TD></TR><TR><TD CLASS="quote">From what I understand the B16B has the best flowbench numbers of the three, and the B16B intake cam is abit more aggressive. Can anyone confirm this?</TD></TR></TABLE>
Don't know about the cams, but the flowbench #'s would surprise me since the b16 head is the same as the b18c5, and the b18c5 has a slight P&P job cleaning up the ports. Don't know for sure though.
Old May 8, 2003 | 10:30 AM
evolve's Avatar
Default Re: B heads (Type R Bob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob &raquo;</TD></TR><TR><TD CLASS="quote">
Don't know about the cams, but the flowbench #'s would surprise me since the b16 head is the same as the b18c5, and the b18c5 has a slight P&P job cleaning up the ports. Don't know for sure though.</TD></TR></TABLE>
Ohh, sorry, I was thinking B16A vs. B18C1 heads, check:
http://www.alaniztechnologies.....html
Old May 8, 2003 | 10:52 AM
msilbernagel's Avatar
You'd want to start with the C1 head only if you have a GSR, because the ports/bolt alignment for the intake differ from the B16/C5 heads.
Other than that, [B][IF/B] you're going to spend the money on the head to fit it out with max perf parts (springs, retainers, valves, p&p) then tbe C5 loses it's advantage -- which <U>is</U> that it comes with good perf parts (just listed) and a mild port.
So if you can save some bucks by picking up a b16 head and you're going to push for performance, take the money you save and use it to pay for the parts and port.
Mark
Old May 8, 2003 | 11:13 AM
NSX Bob's Avatar
New User
Default Re: B heads (msilbernagel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msilbernagel &raquo;</TD></TR><TR><TD CLASS="quote">
Mark
This is true, but if you plan in running ITR, CTR, or other fairly large cams, you will also need to upgrade the b16 valve springs and LMA's, so take those prices into account. If you are planning on getting a full P&P, then the advantage of the slight port job on the c5 becomes irrelevant.
Old May 8, 2003 | 11:54 AM
dfoxengr's Avatar
dont get you head ported...&pd. not worth all the money it costs, for a great job it can be like 6-800$. check this post, ive known this for awhile because my local shop did some tests but heres proof for all you guys. https://honda-tech.com/zerothread?id=499652
Old May 8, 2003 | 12:10 PM
evolve's Avatar
Default Re: B heads (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">dont get you head ported...&pd. not worth all the money it costs</TD></TR></TABLE>
That's how I always saw it. P&P on Honda heads isn't as important as valve area work.
QuickBeeAre
13
Nov 18, 2011 06:25 PM
CivicGSRsi
Dec 3, 2006 05:49 AM
x91crxsix
May 29, 2006 07:35 PM
BIntegra99
Jul 25, 2003 02:57 PM
Matt B
Jan 15, 2002 08:57 AM
