LS\Vtec
Old Jul 24, 2003 | 05:21 PM
BIntegra99's Avatar
Default LS\Vtec
What would you recomend ?...
A B18C1 or C5 Head
or a B16a
Looking for most power...
Old Jul 24, 2003 | 05:32 PM
IntegraLST's Avatar
GO with the B16 a Iiv heard thes work best with ls/vtech's .And I have a few friends that have one
Old Jul 24, 2003 | 05:38 PM
thrty8street's Avatar
Default Re: (IntegraLST)
i second that
Old Jul 24, 2003 | 05:40 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLST &raquo;</TD></TR><TR><TD CLASS="quote">GO with the B16 a Iiv heard thes work best with ls/vtech's .And I have a few friends that have one</TD></TR></TABLE>
well its a lot easier to get than a gsr or a type R
but it aint the best..
Old Jul 24, 2003 | 05:47 PM
BIntegra99's Avatar
Default Re: (francisco flores)
WHat type of power differences would i be looking at between a b16a and a b18c1\5?
Old Jul 24, 2003 | 08:06 PM
prada_2o0o's Avatar
Default Re: (BIntegra99)
either a b16 head or c5 head is supposed to be best.... b16a head flows better than the c1 head.
Old Jul 24, 2003 | 08:23 PM
LoSeR_5150's Avatar
Default Re: LS\Vtec (BIntegra99)
The b16a head and the b18c5 is the same cast, just the b18c5 head has had some minor headwork, the b18c1 will have .2 higher comp then the b16a or b18c5. The b18c5 head also has better cams followed by b18c1 cams, then the b16a cams. Anyways I have an LS/VTEC with a b16a head...
my setup is:I've had a no problem LS/VTEC for about 13,000mi now... my setup is as follows:
LS/VTEC engine converterd, balanced & blueprinted @ 4,000mi (Now has ~40Kmi)
-Type R Oil Pump
-Hydraulic SiR Transmission w/ Cusco LSD
-Clutch Specialites Street/Strip clutch
-2lbs. off B16 flywheel
-USDM ITR pistons
-JDM B16A head
-ITR Intake Manifold
-Mugen ECU
-JDM 4-1 DC Sports Header
-Carsound 2.5" Cat
-Mandrel Bent 2.5" Cat back Exhaust with BOMZ Racing Muffler
-ICEMAN CAI
-B&M Fuel Pressure Regulator
Old Jul 25, 2003 | 01:17 PM
BIntegra99's Avatar
Default Re: LS\Vtec (LoSeR_5150)
Youy can use ITR Pistons on an LS blcok ?
Old Jul 25, 2003 | 01:19 PM
SLYEK's Avatar
im runnin the b16 head on my lsvtec and im very satisfied
Old Jul 25, 2003 | 01:31 PM
FormulaGSR's Avatar
Yes. THe b16 and b18 have the same bores, just different strokes.
Old Jul 25, 2003 | 02:01 PM
Loccster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLST &raquo;</TD></TR><TR><TD CLASS="quote">Iiv heard thes work best with ls/vtech's .</TD></TR></TABLE>
Old Jul 25, 2003 | 02:02 PM
Try2Live4God's Avatar
Default Re: LS\Vtec (FormulaGSR)
Yes you can...they fit in any B-series engine.
Old Jul 25, 2003 | 02:08 PM
BIntegra99's Avatar
Default Re: LS\Vtec (Try2Live4God)
I was told that the b16 only gives like 5-10 hp on top of the ls motor. Is that accurate or nbot ?....I know the b18c5 with rods and pistons will give around 200 whp
Old Jul 25, 2003 | 02:12 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIntegra99 &raquo;</TD></TR><TR><TD CLASS="quote">Youy can use ITR Pistons on an LS blcok ?</TD></TR></TABLE>
yeah you also run CTR as well
but with minor modification to the rod
Old Jul 25, 2003 | 02:57 PM
Triple T's Avatar
All the heads are different it just depends what kind of gains your looking for... If your looking for the most power dont spend the cash on the c5 head when you can find a b16 head and go all out and port/polish it.
If you didnt know ITR pistons fit in an ls block you have a lot more researching to do before you try and put together an ls/vtec. Search around.. theres alot of good info in the all-motor forum. https://honda-tech.com/zerothread?id=501372. Theres good info in that thread too. Just reply with any questions and Im sure I can help seeing how I have an ls/vtec myself.
HiroshimaScreamer
Apr 28, 2009 07:14 AM
CRXEE8
20
Dec 6, 2003 11:29 AM
corgiat
Sep 9, 2003 12:17 AM
SuPeR_MaN
12
Sep 14, 2002 06:19 PM
ridnmyhonda
Jun 2, 2002 09:40 PM
