Valve Cover bolt??
Old Jul 5, 2001 | 09:49 PM
ringgold's Avatar
Default Valve Cover bolt??
A question I always forget to ask until now. I let these guys work on my car awhile back and one of my valve cover bolts the threads in the head are strippeed out somewhat. It doesnt leak any oil but I cant tighten it like it should be tightened and seems to work fine but it bothers me when I can remember it. What exactly can I do to fix this problem rethread it, or what.
Old Jul 5, 2001 | 11:25 PM
Comptech98GSR's Avatar
Default Re: Valve Cover bolt?? (ringgold)
mine had a similar problem, once u take off the valve cover u can replace one of the bolts i had too, it was like 10 bucks, and it screws right in, not a big deal at all.
Old Jul 6, 2001 | 09:34 AM
ringgold's Avatar
Default Re: Valve Cover bolt?? (Comptech98GSR)
Its not one of the bolts that are stripped it is the hole that you screw the bolt down into the threads are stripped in that.
Old Jul 6, 2001 | 10:55 AM
Smashback's Avatar
You can get some stuff to make new threads. Can't remember what it's called, but JB Weld should work if you can't find it. What you'll do is this:
Drill out the threads
Fill hole with JB Weld or whatever
Drill new smaller hole
Tap new hole to accept the thread size on the valve cover bolt
Done. Drink beer
Nice and simple
Old Jul 6, 2001 | 04:57 PM
ringgold's Avatar
Default Re: Valve Cover bolt?? (mplex2000)
Is the stuff that you cant think of named Heli Coil or somehting like that. Are you sure that the JB Weld will work. And forget the beer drink Jagermeister or however it is spelled.
Old Jul 6, 2001 | 06:38 PM
burn's Avatar
New User
heli coil rocks...its a little on the expensive side though...for just valve covers you could probably use just epoxy thread maker.
Old Jul 8, 2001 | 11:56 AM
Leejen's Avatar
Take one of your your good bolts to a hardware store and ask for a tap
that will match that bolt. Re-tap the threads. They could just need that.
Then use a new bolt in that hole, not the mucked up one you took out of it.
Should help.
joshsayswhatt
11
Dec 16, 2009 01:32 PM
SOHC_MShue
95
Dec 20, 2008 04:00 PM
99accordsedanforsale
Classic Hondas
Nov 12, 2007 07:24 AM
reeder321
16
Mar 11, 2004 04:28 PM
bartek_b
Apr 15, 2003 11:21 AM
