True or not?
Old May 6, 2003 | 01:00 PM
Ottoman's Avatar
Default True or not?
i need clarified...
some told me that If I took my d16a9 (137hp) engine and put i/h/e/cams whatever.. and made it 165-170 hp, I would still get killed by the same car with stock b16a t/f?
Old May 6, 2003 | 01:06 PM
Kris's Avatar
Default Re: True or not? (Ottoman)
I think it would be based on the driver from there seeing that you would both be pushing about the same horsepower.
Old May 6, 2003 | 02:56 PM
Ottoman's Avatar
dunno, he claimed the "vtec" makes it a different kinda Horsepower :/
basically trying to justify the expense of goin from a 140hp+ d16a9 and shell out all the money and time for an extra 20-25 horses...
Old May 6, 2003 | 03:01 PM
.RJ's Avatar
.RJ
i/h/e isnt going to make 33 hp on your D16.
Better to swap in a B18C and start with a better overall platform.
Old May 6, 2003 | 03:04 PM
mugensport9's Avatar
Default Re: True or not? (.RJ)
it might be better then the b16 if the new cams u buy have some nasty vtec lobes. it all depends. there are many variables in this equation but for an answer yes u can make it faster then a b16 with th right quality parts. i know the mugen sohc 1.6L had 235hp so thats pretty sick. just goes to show its possible.
Old May 6, 2003 | 03:13 PM
Ottoman's Avatar
well here's my dilemma...
i can source a decent shape B16a used for 600 bux....
problem is that it's mated to an auto tranny, and it doesn't have an ecu...
so i dunno if i could mate the tranny from my d1a and then somehow find a ecu somwhere...
or my other option would be a ZC sohc vtec...
or just stick to the current lump... :/
Old May 6, 2003 | 03:15 PM
Kamin's Avatar
Default Re: (Ottoman)
you cant use a d series transmission on a b series block.
and no i/h/e wont make 33hp
ever.
MAYBE 10 for all 3.
Old May 6, 2003 | 03:18 PM
Ottoman's Avatar
would if be possible to bore out the 1.6 to 1.8 and use 1.8 pistons? would i need a new engine management system?
Old May 6, 2003 | 03:20 PM
.RJ's Avatar
.RJ
yes and yes.
but why not just start with a B18?
Or buy the cheap b16, and get a transmission and ecu for it.
Old May 6, 2003 | 03:23 PM
Ottoman's Avatar
around here Vtec engines are fairly limited...
If i ask around for a b18 ppl laugh at me like i told them there's money growin on trees...
most ppl cheap out and buy accords and preludes with F22's for example... hell even my del sol had a D15z that was swapped to this...
how much would an ECU run me? and how difficult is the swap? new wiring new engine mounts etc etc?
Old May 6, 2003 | 03:42 PM
evolve's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">i/h/e isnt going to make 33 hp on your D16.
Better to swap in a B18C and start with a better overall platform.</TD></TR></TABLE>
Now, now. Some ppl don't like the extra 75lbs.
SCCA Solo, anyone.
Old May 6, 2003 | 05:55 PM
dfoxengr's Avatar
or sicne 1.6 and 1.8 pistons are the same size...you could find the best (highest comp) pistons HONDA made in a jap. b16...
Old May 6, 2003 | 08:17 PM
liquid51's Avatar
Default Re: (hybridvteceg)
Stick with the current lump AS IS until the current non-lump in your back pocket becomes a lump.
imsebtactular
Jul 20, 2007 06:02 PM
latinf86
18
Aug 8, 2006 09:58 PM
C8V6C
10
Feb 8, 2004 07:33 PM
Timmayeg
May 6, 2003 04:54 AM
XLR8 GS-R
Feb 7, 2003 11:50 AM
