Miata rims: What bore size?
I picked up a set of Miata rims (kinda like Panasports) and need to bore out the center hub area but I dont know exactly what to bore it out to. I have seen that they are 53mm and need to go about 56mm to fit the civic hub, is this correct? Any DIY'ers, what did you use to do this?
Yeah i had t do the same thing, i really didnt mesaure anything u just take the air grinding tool, and just take out whole bunch, not too much, put it on the car and see how it fits, wheel should align perfectly with caliper, and when you tighten the lug nuts it shouldnt move side to side. hope this helps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8VTEC »</TD></TR><TR><TD CLASS="quote">Yeah i had t do the same thing, i really didnt mesaure anything u just take the air grinding tool, and just take out whole bunch, not too much, put it on the car and see how it fits, wheel should align perfectly with caliper, and when you tighten the lug nuts it shouldnt move side to side. hope this helps!</TD></TR></TABLE>
do you have a picture of your crx with those miata rims on ??
im also thinking about getting them but not sure what they will look like
thanx in advance
thanx in advance
ive got some 2001's on mine theyre 16s.. i hd the same problem w/ the bore still do acually i just put some spacers in, fits fine now, they sit out futher too cuz they kinda sat in theyre 45+ offset i believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squeaky »</TD></TR><TR><TD CLASS="quote">Here's a pic with Miata rims on my rustbucket. Whee!
nice! smokinsax is putting his miata rims on his '87 civic, so hopefully it will look as good as yours.
we picked them up for 80 bucks WITH tires!
</TD></TR></TABLE>nice! smokinsax is putting his miata rims on his '87 civic, so hopefully it will look as good as yours.
$80 is a good deal. Just remember to drill out the center hole a little bit so the wheels are mounted properly. I just used a hole saw on my hand drill and went at it. Took less than 30 minutes to do all four.
dsprimal
Jun 12, 2012 09:26 PM
