1998 civic hub bore size. +10 offset question
hey all, are 1998 civic hub bore size 56.1? Reason why i'm asking is because the bore size for the rims i'm gunna buy are 57.1 which is a minimal difference would I need lug nut rings or w.e they're called to fill in the excess space?
also for a +10 offset would i need any spacers to install these rims properly? thanks
Re: 1998 civic hub bore size. +10 offset question
they are called hub rings.
and whether you need them or not depends on one thing.
is your rim a lug centric, or hub centric design?
if its lug centric then you do not need the hub ring
if its hub centric, then you do need the ring.
i have not yet seen a hub centric 4x100 civic wheel yet.
because on lug centric rims the rim actually rides on the lugs (thats why they have a conical shape where they meet the rim ( to center it )
+10 are going to stick out way more than stock so no you shouldn't need a spacer. the wheels probably wont fit well with that low of offset. there are tons of threads on this topic
i've seen these rims on 6th gen civics before. but i'm worried about rubbing of the fender. i have a subtle drop. i still have about half an inch worth of wheel gap. i'm going with low pro tires tho when i do buy these rims. what would i need to make sure they fit flush?
thanks man, so 1mm difference wont matter?
just search "offset" in the wheel and tire forum, you will find plenty of info
https://honda-tech.com/forums/showth...ghlight=offset
I want these wheels:
http://www.ebay.com/itm/370577702711...ht_2122wt_1402
the hub bore is 75 tho. will i definitely need hub rings? if so can anyone link me to the ones i need?
thanks
thanks
julioboostamante
08-25-2008 07:39 PM
