Do you need to jump the service connector?
Old Jul 5, 2001 | 11:51 AM
LostGsr's Avatar
Default Do you need to jump the service connector?
Is it necessary to jump the service connector just to check the timing? I know you need to warm the car up.
Old Jul 5, 2001 | 12:18 PM
miketegra's Avatar
Default Re: Do you need to jump the service connector? (LostGsr)
Yes it is.
My man GeeSeR has all the answers: http://integra.vtec.net/geeser/service_connector.html
Old Jul 5, 2001 | 04:26 PM
G3-GSR's Avatar
New User
I didn't use it to check the timing on my 98 GSR, but I did have the jumper in when I advanced the timing. I've checked the timing with and without the service connector in, there was no difference. If you do change the timing, make sure the 'check engine' light is on after you jump the connection. If it's not, the connection isn't jumped and the ECU will compensate for any changes you make.
Old Aug 2, 2011 | 12:12 AM
fAyJai510's Avatar
Need help here..
i have 90 civic si with b18b, trying to do my timing but when i jump the service connector there no check engine light on. help please
Old Aug 2, 2011 | 06:28 AM
GagnarTheUnruly's Avatar
AFIK the ECU only flashes the CEL if you actually have an error code. Otherwise, doesn't it stay off when the service connector is jumped?
Old Aug 2, 2011 | 01:29 PM
fAyJai510's Avatar
no i have no error code...just want to do the timing it. it stay on or off when it jumped?
Old Aug 2, 2011 | 03:05 PM
thewrai6th's Avatar
IIRC, Solid ON while jumped
Old Aug 2, 2011 | 03:19 PM
Now you say it that sounds right to me. Never paid much attention to it I have to admit...
Old Aug 3, 2011 | 09:37 AM
k20ftw's Avatar
should always be solid on when jumped.
Old Aug 4, 2011 | 04:08 AM
turbodcxbro's Avatar
Yes its necessary to jump it to PROPERLY set timing and the CEL should be on when jumped, if not you didn't do something right!
Car should be warm and idle speed should be steady and set to the manual.
4dek
Jul 6, 2008 10:51 AM
burningwrek
30
Aug 24, 2004 04:10 PM
extrmeboost
Feb 8, 2003 07:13 AM
Boostless97Lude
Jan 7, 2003 08:24 AM
