Help a noob out please! -= Heater circuit malfunction=-
Old May 5, 2003 | 07:24 PM
iam7head's Avatar
Default Help a noob out please! -= Heater circuit malfunction=-
just pulled the cel off my accord.
it's on my turbo'ed accord, the o2 sensor prolly got knock out already.
it's cel 65 and 41
heater circuit malfunction
Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
what should i do? the thing is that my o2 sensor(primary) is replaced and it still throw me the code(soft code).
Should i go ahead and put on the secondary one or else what should i do?
thanks in advance
Old May 6, 2003 | 12:44 AM
.bagged's Avatar
Default Re: Help a noob out please! -= Heater circuit malfunction=- (iam7head)
Sometimes with the addition of an aftermarket turbo you have to add a secondary o2 sensor. i would try that.
Old May 6, 2003 | 05:16 AM
jweller's Avatar
Default Re: Help a noob out please! -= Heater circuit malfunction=- (bagged93accord)
O2 sensors don't read very accurately until they get up to their proper operating temperture. that takes a couple minutes under normal operating conditions. They put a heater in the O2 sensor so that it will warm up quicker. This lowers cold start emissions.
If you can live with the CEL, it's not an issue. You are just putting out a little bit more emissions for the first couple of mins the car runs.
Old May 6, 2003 | 02:03 PM
iam7head's Avatar
Default Re: Help a noob out please! -= Heater circuit malfunction=- (jweller)
Will a new O2 sensors do the trick?
or where should i look?
Jweller, once again i want to thank you.
Old May 7, 2003 | 06:12 AM
JimBlake's Avatar
Sensor heater circuit is just a 12v power supply to work the heating element that's built into the O2 sensor. Unplug the sensor, check continuity thru the heating element with a DMM. If that's open, then all you can do is get a new sensor. If it's OK then you check to see if there's really 12v power at the plug. If not, then you gotta look for blown fuses or broken wires...
Old May 7, 2003 | 09:21 PM
iam7head's Avatar
Default Re: Help a noob out please! -= Heater circuit malfunction=- (JimBlake)
which fuse should i be check?
I already got new oxygen sensor installed, same code pop put after
a while.
Old May 8, 2003 | 03:08 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">which fuse should i be check?
a while.</TD></TR></TABLE>
What year and model?
Old May 8, 2003 | 04:42 AM
jweller's Avatar
Default Re: Help a noob out please! -= Heater circuit malfunction=- (Chiovnidca)
just saw this link posted. thought you might find it interesting. It's about how the O2 sensor works
http://www.bondauto.com/templa...id/20
Old May 8, 2003 | 02:34 PM
iam7head's Avatar
accord 2002 ulev 4 cylinder(up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
What year and model?</TD></TR></TABLE>
Old May 8, 2003 | 04:33 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">accord 2002 ulev 4 cylinder(up)
Fuse #6 in the drivers under dash fuse box.
Old May 8, 2003 | 05:19 PM
JimBlake's Avatar
My Helm book only covers '98 & '99, but for the F23A4 engine (is that what you got?), fuse #6 on the passenger's side is also involved, and there's a relay somewhere, too.
Old May 8, 2003 | 05:40 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">My Helm book only covers '98 & '99, but for the F23A4 engine (is that what you got?), fuse #6 on the passenger's side is also involved, and there's a relay somewhere, too.
Your right, I missed the ULEV part.
Old May 10, 2003 | 01:25 AM
iam7head's Avatar
Let me check it right now...
Old May 11, 2003 | 05:02 PM
iam7head's Avatar
put in new o2 sensor for primary and secondary, one code is gone.
Only code 41 is left, checked fuse the fuse is good.
what should i do? will it harm performance in anyway?
Old May 12, 2003 | 04:10 AM
JimBlake's Avatar
41 is the heater circuit for the primary O2 sensor. If it's like '98/'99, that's the one with a relay. Check to see if you have 12v power for that heater, then get a circuit diagram for your car (got a Helm book?) Check wiring & relays 'til you find an open (disconnected) wire someplace. We had you check fuses since they're easier to check & more likely to be the cause of the trouble. You're gonna learn to your DMM...
Without a heater, the O2 sensor takes longer to get hot & start working. But I'm not sure whether the heater stays on & keeps the sensor hotter than it would be if it was just heated by the exhaust.
Old May 12, 2003 | 05:52 AM
iam7head's Avatar
thank alot..i dont have the helm
where is the fuse located at? i want double check the fuse too.
what's the name of the fuse?
the heater is the black wire right?(i have 2 black btw)
I have the primary sensor extended(with solder and wires) for the header.
do you think that might cause it?
Old May 12, 2003 | 07:29 AM
JimBlake's Avatar
I'm not sure, I don't have my repair book with me. Besides, it's not for your year, so I gotta be careful about that.
You have a F23A4? In '98 & '99 that was fuse #6 on the passenger side. I don't know where the relay is located, I don't have that engine & I only spent a couple minutes looking for it. It might not be the same for '02 anyway.
The heater leads coming from the sensor should read some (finite) resistance. When the sensor is cold I think the leads for the sensor itself will look like an open circuit.
If you did an OK job soldering the wires, that shouldn't be the problem.
Old Jul 9, 2003 | 03:38 AM
iam7head's Avatar
Just installed a working condition oem honda o2 sensor and guess what?
the cel came back on.
I checked the fuse, it's fine.
what's going on??
Old Jul 9, 2003 | 01:29 PM
iam7head's Avatar
Bump
Old Jul 9, 2003 | 02:09 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">Just installed a working condition oem honda o2 sensor and guess what?
what's going on??</TD></TR></TABLE>
Have you checked the wiring And connectors back to the ECU?
Old Jul 9, 2003 | 05:12 PM
CaptainObvious's Avatar
I had same problem...Go to Autozone and for $89.99 you can get a shinny new o.e.m. o2 sensor...i thought it was my heater circuit when i got code 41 but it was the sensor itself... before you spend any money check your driver side fuse box located right in front of the door by your pedals. Chances are o2 sensor needs to be replaced.
Old Jul 11, 2003 | 06:24 PM
iam7head's Avatar
Default Re: Help a noob out please! -= Heater circuit malfunction=- (CaptainObvious)
tried new oem sensor also, same code.
the sensor got hot like **** after 20-30 second with it unplug sitting out side of the downpipe=circuit=working
Old Jul 11, 2003 | 06:50 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">tried new oem sensor also, same code.
the sensor got hot like **** after 20-30 second with it unplug sitting out side of the downpipe=circuit=working</TD></TR></TABLE>
Do you have access to another ECU to try?
Nooget
13
Aug 14, 2010 08:12 PM
importdreamer
May 26, 2007 06:58 PM
Twixle
May 8, 2007 01:10 PM
mxl36o
Aug 4, 2006 06:09 PM
Etylorcen
May 6, 2002 04:28 PM
