22 VTEC pressure valve...How do I clear this code?
Old May 5, 2003 | 12:58 PM
Hondasaurs's Avatar
Default 22 VTEC pressure valve...How do I clear this code?
I just checked myCEL codes. I've gone throught all the basic checks like oil level and all that. What do I need to do?
Modified by ZC_CRX at 5:11 PM 5/5/2003
Old May 5, 2003 | 01:03 PM
accordhybrid's Avatar
Default Re: 22 VTEC pressure valve...How do I clear this code? (ZC_CRX)
Have you always had the code? If so try regrounding the wire and also make sure you have a good connection to the ecu
Accordhybrid
Old May 5, 2003 | 01:10 PM
Hondasaurs's Avatar
Default Re: 22 VTEC pressure valve...How do I clear this code? (accordhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordhybrid &raquo;</TD></TR><TR><TD CLASS="quote">Have you always had the code? If so try regrounding the wire and also make sure you have a good connection to the ecu
Accordhybrid</TD></TR></TABLE>Yes, ever since I did the swap I've had the code. I'lll try regrounding it and checking my ECU connections.
Old May 5, 2003 | 01:34 PM
eg6ajk's Avatar
on quick way of getting rid of the problem is to splice it to the vtec solenoid wire. no more check engine and vtec will activate (trick done for those running obdI ecu and OBDII JDM motors)
Old May 5, 2003 | 03:00 PM
Hondasaurs's Avatar
Default Re: 22 VTEC pressure valve...How do I clear this code? (eg6ajk)
I just solved the problem. Thanks for your help!
Jdmkids Manny
17
May 12, 2016 02:18 PM
gots_a_sol
Aug 4, 2004 05:32 PM
SlippylesKB
Sep 3, 2003 07:46 AM
Mentat Ghola
May 15, 2003 10:15 PM
prjctCIVIC
Jul 7, 2001 09:50 PM
