f22b1 into ek- what axles?
Old May 4, 2003 | 10:50 PM
vladd's Avatar
Default f22b1 into ek- what axles?
i plan on swapping a 96 f22b1 into an ek. what axles will i need to use? i can't afford aftermarket ones, so i need to figure out how to rig some up. i have the stock accord axles, can i do anything with those?
Old May 5, 2003 | 12:48 AM
00b16's Avatar
Default Re: f22b1 into ek- what axles? (civicdxtyper)
I'm not a hundred percent sure, but I believe this to be the same as the h22 swap. In which case you would just need the 90-93 integra axles and the same for the shift linkage. But again, I am not a hundred percent sure on this. Good luck.
Old May 6, 2003 | 07:18 PM
vladd's Avatar
Default Re: f22b1 into ek- what axles? (00b16)
thanks for the info . can anyone confirm this for sure?
Old May 7, 2003 | 11:12 AM
kikicamacho's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info . can anyone confirm this for sure?</TD></TR></TABLE>
Can someone confirm this? My cousin and I might do a f22b1 (96 accord EX) into and EG Sedan. We have the ECU and Tranny as well as axles from the Accord. All we need are mounts, linkage, and axles.
Old May 8, 2003 | 11:15 PM
yellaboi's Avatar
Default Re: f22b1 into ek- what axles? (macho-camacho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macho-camacho &raquo;</TD></TR><TR><TD CLASS="quote">
Can someone confirm this? My cousin and I might do a f22b1 (96 accord EX) into and EG Sedan. We have the ECU and Tranny as well as axles from the Accord. All we need are mounts, linkage, and axles.</TD></TR></TABLE>90 -93 axles for eg not sure on ek
Old May 9, 2003 | 01:17 AM
NXSpoon's Avatar
Hey, I will be doing the same thing this summer in a 94 DX. Glad to hear someone else is giving it a shot.
Check out the following, hope this helps some.
Also, Newman has a post re: axles.
https://honda-tech.com/zerothread?id=487983
BBallz24
Jan 10, 2008 05:10 PM
nicko360
Aug 20, 2007 06:43 PM
DFW
Sep 8, 2006 12:04 PM
SoySauc3 H22atch
Nov 16, 2005 08:52 AM
BOOSTonHAnD
Jun 10, 2004 09:20 PM
