need more fuel
Does anybody know what size injectors i need for 4-6 psi on slightly built h22 motor. new rings old pistons? i was thinking about using 95 jdm's which flow around 290. is that enough?
I'd find a set of 93-95 VTEC's. 330's should be MORE than enough to handle 4-6 psi.
Worse comes to worse, get a real fuel controller that can turn the pressure and volume down, and find you a set of DSM 440cc's. They're dirt cheap.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMOOTH97LUDE »</TD></TR><TR><TD CLASS="quote">is it true that for bigger injectors than 370 u need some type of stand alone computer?</TD></TR></TABLE>pretty much, or you could just tune a VAFC to cut back on fuel, tricking the ECU, it'd take a good hack to make it work well
AEM EMS
