SAFC Field Controller
Old Dec 4, 2004 | 02:49 PM
mprelude's Avatar
Default SAFC Field Controller
What would i need to get more fuel into the motor cause if i have the safc and i set my fuel to get more fuel. it wouldnt make any difference cause i have the stock injectors etc.. so just give me ideas of what i should get or do.
Old Dec 4, 2004 | 05:31 PM
xbn83's Avatar
Default Re: SAFC Field Controller (mprelude)
Is your car running lean, and is that why you need to pump more fuel? But if you think dumping more fuel into the engine will make your car run faster, it is not true. Did you dyno tune your SAFC? I have fuel pressure regulator and VAFC running on stock h22 injectors. I could make my car run rich like hell by either increase the fuel pressure or change the fuel curve setting on the VAFC.
Old Dec 4, 2004 | 07:53 PM
lakerschamp2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mprelude &raquo;</TD></TR><TR><TD CLASS="quote">What would i need to get more fuel into the motor cause if i have the safc and i set my fuel to get more fuel. it wouldnt make any difference cause i have the stock injectors etc.. so just give me ideas of what i should get or do.</TD></TR></TABLE>
yes, by hooking up that safc to your ecu, it will add more fuel, depend on your setting
existanzcivicb20
Apr 20, 2006 09:23 PM
Tchleung
Feb 27, 2005 07:52 PM
7rrivera7
May 10, 2004 06:13 PM
oryanh
Jan 1, 2002 11:36 AM
LSCivic
11
Sep 25, 2001 08:19 AM
