How hard is a timing belt and cam shaft removal/installation?
Old May 4, 2003 | 07:00 PM
RTW DC2R's Avatar
Default How hard is a timing belt and cam shaft removal/installation?
I plan to install a hondata IM gasket in the near future, and since Im in there, Im very tempted to install a thinner head gasket to boost my compression a tad bit more. Id like to do the work myself for a change, rather than get raped on labor charges. Im pretty confident I can handle it with the Helms at my side, but it would be my first attempt at major work on my car. I was there when my motor was taken apart the first time so Im familiar with the process and the helms can provide me with specs and whatnot, but Ive never really wanted to attempt to mess around with the cams/timing belt myself. Just curious if any of you guys had any bad experiences with your first timing belt/cam shaft install or removal and maybe you have some tips I could keep in mind. Thanks.
Old May 4, 2003 | 07:01 PM
.RJ's Avatar
.RJ
Default Re: How hard is a timing belt and cam shaft removal/installation? (RTW DC2)
You can remove the manifold w/o removing the head...
Unless you want to remove the head. Its not very hard with the Helms, should take about 3 hrs or so.
RJ
Old May 4, 2003 | 07:14 PM
RTW DC2R's Avatar
Default Re: How hard is a timing belt and cam shaft removal/installation? (.RJ)
yeah i know i dont have to remove the head for the IM gasket, just figured since i was gonna be in there, might as well kill 2 birds with one stone. any kind of special tools/lubes/cleaners i might need? if i recall correctly, the pieces that hold the retainers on(forget the name) were sort of a bitch and you needed a tool to hold the spring down so u could put the pieces on.
Old May 4, 2003 | 07:18 PM
.RJ's Avatar
.RJ
you dont need to remove those to get the head off.
no special tools.. pbblaster on header bolts works well... some liquid gasket for the cam seals, and a clean workspace. Breaker bar and torque wrench for the headbolts too.
Old May 4, 2003 | 07:22 PM
baonest1's Avatar
RJ is right on target. nothin some home tools cant do. and make sure you follow the sequence of headbolt removal
Old May 4, 2003 | 07:23 PM
RTW DC2R's Avatar
for some reason I was thinking I had to remove the valvetrain.
OK so that makes thing actually seem a lot less complicated.
Old May 4, 2003 | 07:25 PM
.RJ's Avatar
.RJ
dont forget to drain the coolant out of the block (19mm bolt behind the header, need a 3' breaker for it) before you pull the head off. Dont ask me how i know.
Old May 4, 2003 | 07:26 PM
baonest1's Avatar
he is right about that too.. make sure you apply liquid gasket to the threads when you put it back on.
Old May 4, 2003 | 07:27 PM
RTW DC2R's Avatar
Default Re: How hard is a timing belt and cam shaft removal/installation? (baonest)
Ive already got ARP studs, but the torque specs should be the same right
Old May 4, 2003 | 07:28 PM
.RJ's Avatar
.RJ
my breaker bar (big steel pipe) was about face level when i was breaking that bitch loose. And then it broke loose. And my roomate was about to fall over laughing - he stopped for a second to say "dood, you just own3d yourself in the face!" and kept laughing.
I'm glad they like to sit around and drink beer while i work on my car.
Old May 4, 2003 | 07:29 PM
baonest1's Avatar
63 if i am not mistaking. i threw the sheet away a while ago, im just using memory from when i installed my head with ARP studs. but its a 2 step process. 25ftlb first, then 63ftlb. someone please confirm the right spec.
yah and make sure you use a breaker bar or somthing big. cuz you could throw your elbow out. almost happened to me, but i was busting motor mount nuts loose on a toyota. **** hurt. but it was only 3 nuts
Old May 4, 2003 | 07:31 PM
.RJ's Avatar
.RJ
follow the specs that came with your studs... not the helms for these.
RTW DC2R's Avatar
yes i checked the helms, it is 63ft/lbs for the stock head bolts. i just wasnt sure if the ARP studs used a different torque spec or not.
Ill try to find out what ARP recommends.
Old May 4, 2003 | 07:33 PM
baonest1's Avatar
https://honda-tech.com/zerothread?id=494573 i found this.
https://honda-tech.com/zerothread?id=435341
70 with the lube it comes with. 83 with oil
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">yes i checked the helms, it is 63ft/lbs for the stock head bolts. i just wasnt sure if the ARP studs used a different torque spec or not.
Ill try to find out what ARP recommends. </TD></TR></TABLE>
Check with ARP. Follow the same sequence in the book.
Old May 4, 2003 | 07:34 PM
Tommy_Gunns's Avatar
If you don't have air tools, good luck on the crank pulley bolt. If you are gonna do all that work you might as well change the timing belt and water pump.
Old May 4, 2003 | 07:36 PM
baonest1's Avatar
Default Re: How hard is a timing belt and cam shaft removal/installation? (Tommy_Gunns)
how many miles are on the car?
Old May 4, 2003 | 07:37 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommy_Gunns &raquo;</TD></TR><TR><TD CLASS="quote">If you don't have air tools, good luck on the crank pulley bolt. If you are gonna do all that work you might as well change the timing belt and water pump.</TD></TR></TABLE>
that was the plan, water pump is new, but i wanna go with a aftermarket belt as well as a ATI pulley.
one thing leads to another....damn im broke.
Old May 4, 2003 | 07:38 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=494573 i found this.
70 with the lube it comes with. 83 with oil</TD></TR></TABLE>
Thanks
Old May 4, 2003 | 07:40 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">how many miles are on the car? </TD></TR></TABLE>
only 127 miles since the first buildup lol. I dont plan on doing this immediately, after I break it in some more.
jermo
Honda Civic (2001 - 2005)
Jul 30, 2014 02:26 PM
JJT211
May 25, 2014 07:38 AM
niceguyjp2183
May 9, 2006 02:51 PM
Mr. Thunderlips
Nov 7, 2002 11:18 PM
