Header install mess up, HELP!(
Old May 4, 2003 | 01:24 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Header install mess up, HELP!(
I didnt think it was possible to **** up on a header install, but urs truly has. I removed the two clutch slave cylinder bolts and pushed the cylinder out of the way so i could get the header to come up from the bottome and fit. All went well, bolted everything back up and she was lookin pretty. Then i went to start it and BAM, clutch peddle to the floor. I knew it was the clutch slave cylinder leaking, and sure enough, fluid is dripping quickly. So what do you guys think it is? Did i pop a gasket or something from the slave? Ideas?
Rguy, whose back hurts from laying on gravel..
Old May 4, 2003 | 01:26 PM
disordeR's Avatar
Default Re: Header install mess up, HELP!( (Rguy)
You shoulda been able to slide/angle the header out and in w/o removing the clutch slave cylinder.
Old May 4, 2003 | 01:27 PM
Bbasso's Avatar
Take a look at the slave and see if you could push it back together and see if it will hold, If not You might need to get another one.
Rguy's Avatar
25 Year Member
Community Builder
Ill go take a look at it...
Old May 4, 2003 | 01:38 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: (Rguy)
Took a look at it, Its definitely disconnected in at least one place. Did i pull the thing out of the block? Is that easy to do?
Old May 4, 2003 | 02:23 PM
jdmspoonitr's Avatar
Default Re: (Rguy)
Yup....no need to touch any of that. Just angle the passenger side of the header up and drivers side down and slip it out. It is a tight fit, but there is no need to remove anything but exhaust components to install a header on this car.
Old May 4, 2003 | 02:31 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">Yup....no need to touch any of that. Just angle the passenger side of the header up and drivers side down and slip it out. It is a tight fit, but there is no need to remove anything but exhaust components to install a header on this car.</TD></TR></TABLE>
Well if was takin it out, or putting it in that would be good advice. But the header and everything is bolted up. Im good to go there. Im sitting here looking at the slave cylinder, with the actual "piston" thing no longer in the cylinder.
Old May 4, 2003 | 02:32 PM
Flux's Avatar
That isn't helping him now...
Old May 4, 2003 | 03:42 PM
Dr Pooface's Avatar
Default Re: (Rguy)
Try putting it back together and see if it works.
Old May 4, 2003 | 04:26 PM
98TypeR's Avatar
remember to fill your fluids up again.
brake fluid will be okay.
Old May 4, 2003 | 04:29 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: Header install mess up, HELP!( (98TypeR)
Yeah i know, im gonna fill it up and bleed the system when i figure out what i need to do with these two pieces of the slave cylinder..
Old May 4, 2003 | 04:49 PM
py1188's Avatar
I've heard of this happening to someone as well. Slave cylinder went bad. Thats all i really remember, wish i had more details to help you
Old May 4, 2003 | 04:53 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: Header install mess up, HELP!( (py1188)
Its not the master cylinder, my clutch was working fine.Then i disconnected the slave cylinder it from the block and it fell apart. Hence my problem.
Old May 4, 2003 | 04:58 PM
py1188's Avatar
Sorry it was a typo, I meant to type slave, it did have to be repalced though.
Old May 4, 2003 | 07:12 PM
Rguy's Avatar
25 Year Member
Community Builder
anyone? Can i just pop the piston back in the slave cylinder and refill with fluid and go? I gotta get this bastard workin ASAP.
Old May 4, 2003 | 07:15 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">Can i just pop the piston back in the slave cylinder and refill with fluid and go? </TD></TR></TABLE>
Make sure it is clean and slide it back in (try twisting it a little bit).
Install it and bleed the line. It will have a bunch of air at first and you may need to bleed it again tomorrow.
Old May 4, 2003 | 07:20 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: Header install mess up, HELP!( (Willard)
Thanks Willard.
Old May 4, 2003 | 07:31 PM
DeL SLo's Avatar
Same thing happened to me. Except it was my ex-gf who pulled on the slave cylinder too hard and broke it while I was installing the header. We did the same thing on my friends car and I pulled the sc (but i was really careful) and his didnt break. I just went and bought a new sc. it was about $70 and I bled the clutch myself which took 3-4 hours!!!
Old May 4, 2003 | 07:33 PM
DMF's Avatar
DMF
We did the same thing to my roommates car. You just need to re-assemble, re-install, and bleed. You can use brake fluid for this as well.
Old May 4, 2003 | 07:41 PM
YellowKahuna's Avatar
That sucks.
polishedturd
Feb 8, 2008 03:32 AM
The Acclude v 2.0
Jun 21, 2003 11:01 AM
lude97dude
May 19, 2003 02:32 PM
2000BoostedEX
May 8, 2003 08:47 PM
dnt94civic
Feb 28, 2003 03:28 AM
