my tach is crazy again...
Old May 4, 2003 | 06:23 PM
crxtreme27's Avatar
Default my tach is crazy again...
every time i get to about 4000 rpm's my tach starts to just jump up and down, there is no change in the engine, its just the needle and it seems to just happen for the first 10 or 20 minutes i drive the car, after that it goes away.... i had this problem before and all i did was changed the rotor and it went to normal.. but now what can it be??
Thanks
Old May 4, 2003 | 06:25 PM
Hondasaurs's Avatar
Default Re: my tach is crazy again... (crxtreme27)
This is a sign of your ignitor going bad.
Old May 4, 2003 | 11:30 PM
FR-MOB: ThE bEe GuY's Avatar
you didnt recently clean your engine did you? that happened to mine when i cleaned my engine, the dist. plugs just got wet...dried them and it works fine now
Old May 5, 2003 | 03:36 AM
spiceisler's Avatar
Default Re: my tach is crazy again... (ThE bEe GuY)
Cleaned my engine the other day and the same thing happened. Not only did the tach jump I also had a hesitation/miss at take off. Changed the igniter, all is well now.
Old May 5, 2003 | 07:15 AM
REDBARON's Avatar
Default Re: my tach is crazy again... (clean90Si)
Happened to my brother. Changed the ignitor, and all is well.
wnp94
Sep 23, 2014 10:10 PM
OMG WTF
Nov 10, 2006 08:31 AM
boostedteg15
Aug 4, 2006 06:55 PM
AMChev
Nov 1, 2005 05:49 AM
datac99
May 23, 2005 01:52 PM
