tubor charge a d15z1 vtec-e?
Old May 1, 2003 | 07:46 AM
vtec-eCIVIC's Avatar
Default tubor charge a d15z1 vtec-e?
are their turbo kits for a d15z1 vtec-e?
Old May 1, 2003 | 07:54 AM
orange.honda's Avatar
Default Re: tubor charge a d15z1 vtec-e? (vtec-eCIVIC)
well in reality any kit for any dsieries will work. all the bolt patterns on the exhaut mani are the same. but it might not be portmatched to you specific application. also the vx tb is way smaller so you would prbably need an adapter. but for the most part any turbo for a sohc d16y8/z6 will work.
Old May 1, 2003 | 08:41 AM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec-eCIVIC &raquo;</TD></TR><TR><TD CLASS="quote">are their turbo kits for a d15z1 vtec-e?</TD></TR></TABLE>
no but you make a custom built though.
I wouldn't bother turbocharging a vtec-e engine since it already runs extremly lean from the factory and made for fuel economy. not that all honda civics are designed that way in the first place from the factory. now if it was a regular d15 non-vtec, it would be a better choice. it's your choice
Old May 1, 2003 | 06:23 PM
i understand that it is not a power house however, no one ever builds up a d15z1, i would like to, what are some good brand to look for?
Old May 1, 2003 | 07:01 PM
Default Re: tubor charge a d15z1 vtec-e? (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't bother turbocharging a vtec-e engine since it already runs extremely lean from the factory and made for fuel economy. not that all Honda civics are designed that way in the first place from the factory. now if it was a regular d15 non-vtec, it would be a better choice. it's your choice</TD></TR></TABLE>
well even if it is true, i say you build it anyway prove him wrong. if it runs lean just get bigger injectors, upgrade to a p28, bump up fuel pressure, or do a mini me with a z6 or y8 head. there are lots of ways to fix that problem. if you buy an fmax kit it comes with 2 additional mf2 controlled injectors in the throttle body.
Modified by orange.honda at 10:12 PM 5/1/2003
maintain
May 15, 2008 08:34 PM
vtec99ej
24
Jan 28, 2007 11:01 AM
949
12
Jul 24, 2006 05:18 PM
98silvercivicEX
Feb 15, 2004 12:27 PM
Dasani
50
Dec 6, 2003 09:04 AM
