Did the MPFI swap but car won't start - what should I check?
Old Apr 30, 2003 | 06:20 PM
OldSchoolHatch's Avatar
Default Did the MPFI swap but car won't start - what should I check?
I did the MPFI swap but it won't start. It doesn't do anything when I turn the key, but the ECU is giving a code 10. I won't be able to check for a spark until tomorrow, since the car's at my school. I could have done some of the wiring or hoses wrong, since I used parts from both a 4wd wagon and Si. Can anyone give me a list of things to check that would stop it from starting, and tell me the easiest or best order to check them in? I won't have too much time to work on it...
Old Apr 30, 2003 | 06:30 PM
civbeater90's Avatar
Default Re: Did the MPFI swap but car won't start - what should I check? (OldSchoolHatch)
check your grounds
Old Apr 30, 2003 | 06:37 PM
Default Re: Did the MPFI swap but car won't start - what should I check? (civbeater90)
can you list all the grounds? and do you have any other ideas?
Old Apr 30, 2003 | 06:38 PM
FourthGenHatch's Avatar
10 is TA Sensor, aka Temperature sensor found on the #1 runner on the intake manifold. Most likely if you did MPFI swap you have the sensor near the throttle body (with the white plug on its harness) plugged in there this TA sensor should be. I did the same thing, plug plugs fit each other, just swap them and try. It shouldn't prevent your car from starting but that will eliminate that code. Try and check your firing order also.
Old Apr 30, 2003 | 06:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldSchoolHatch &raquo;</TD></TR><TR><TD CLASS="quote">can you list all the grounds? and do you have any other ideas?</TD></TR></TABLE>
1. Body to Valve cover (should be pretty obvious)
2. Battery to Body to Tranny (will be under your battery tray
3. Thermostat
What I did was make my own new grounds. When I did that I sanded down the area aroudn where they bolt in with a dremel so I get a really good contact.
Old May 4, 2003 | 02:09 PM
91civicEX's Avatar
Check distributor wires. also i found out that if you rewire the distributor while its connected to the car it wont start. you have to take it out rewire it and put it back in. . also did your ecu flash any other codes? remember the green plug goes to the EACV on the back of the manifold. and the white plug with the shorter wires goes to the IAT. the white plug with long wires doesnt pluf into anything. it just hangs there.
Vlad
Old May 4, 2003 | 03:53 PM
Default Re: (91civicLX)
Thanks for the tips. I forgot to post an update, but I did get the car to start. I also fixed the problem that was giving me a code 10 on the ECU. It's still not running right though, so I'll have to play around with it.
When I ran the two wires from the computer to the distributor, I forgot to label which was which. So I just guessed and I don't know which way is right, since it's not running how it should when I switch it either way. I still have to fix some other problems, but does anyone know what difference it would make if these two wires were switched?
Old May 4, 2003 | 04:17 PM
91sleeper's Avatar
off subject but what is the MPFI swap and what does it stand for
Old May 4, 2003 | 04:22 PM
93eg-EKhybrid's Avatar
Default Re: (91sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sleeper &raquo;</TD></TR><TR><TD CLASS="quote">off subject but what is the MPFI swap and what does it stand for</TD></TR></TABLE>
You see that SEARCH button at the top??? Press the button and type in MPFI and you will gets pages of useful information.
brad22486
20
Mar 24, 2012 09:08 AM
jdm206
May 15, 2007 12:00 AM
gezer
18
Oct 31, 2004 06:55 AM
cd1fidy
Jun 25, 2004 03:32 AM
TOFU.man
May 30, 2004 10:54 PM
