Car wont start again
Pos wont start again 92 hatch w obd2 gsr swap used singe cam harness to get it started before pulled swap back out to put new seals in tranny put back in and now wont start main relay is making a buzzing noise and i tried 2 dif ones and both do the same thing its not getting spark or fuel i dont understand i pulled swap back out to make sure i didnt pinch any wires. Will it mess anything up if i pull motor when its still hot any suggestions will b appreciated i guess if i didnt have bad luck i wouldnt have any at all
Re: Car wont start again
I traced the 4 ground wires from the thermostat to the ecu and spliced in and regrounded em inside the car and still nothing no spark or fuel
you said your relay is clicking? And it usually needs to be grounded on the motor. I had a friends car where they tried to ground the thermo ground on the chassis and it didnt work out.
Well i feel stupid as **** where i have my wires tucked the 2 plugs were mixed up so car runs now. But still cant get my wipers or horn to work
The Grumpiest
Somebody should shoot you. You didn't think it important to mention right off the bat that you did a wire tuck? I bet you your wipers not working is also due to the shoddy tuck job.
BOOSTEDgreeneg
09-06-2005 10:06 AM
No More Civic
10
08-27-2002 09:35 AM
