critique my setup and tell me what you think, please
1.* Garrett TA34 - .63a/r turbine stage 3 wheel
.60a/r compressor 60 trim
2.* Custom SS Manifold - The Drop Shop
3.* Custom 2.5 inch Downpipe w/ Flexpipe - The Drop Shop
4.* Dumptube (closed-looped) - The Drop Shop
5.* Tial 35mm HP Wastegate
6.* HKS Super Sequential BOV
7. Maxrev Intercooler
8.* DIY Intercooler piping 2.25"
9. Hosetechniques - silicon couplings
10. Steel Braided Oil Kit
11. Golden Eagle Mfg. VTEC conversion/turbooil feed kit
Engine:
1. JE Pistons 10.0:1 compression ratio 87mm
2. Crower Rods
3. Darton Sleeves 87mm
4. align Bore or Hone
5. Micropolished Crank
6. Fully Balanced & Blueprinted
8. Skunk2 Cam Gears
9. ARP Head Studs
10. ACL Bearings - not sure if there is an h23a app
Fuel Delivery:
1.* CPR 72lb. Injectors
2.* AEM Fuel Pressure Regulator
3.* AEM Fuel Rail
4.* Walbro 255lph Fuel Pump
Fuel Management:
1. Hondata s200 w/boost
2. Romulator
3. G-Sensor
4. HondaLogger
5. Pocket Programmer
6. ROM Editor V3
7. FJO Lambda meter
8. P28 OBD1 GSR ECU
9.* OBD2 - OBD1 Adapter Cable
10. Wideband o2 sensor
Exhaust:
1. Custom Magnaflow Cat 2.5"in/3"out
2. Custom SS 3" Exhaust Piping
3. Blitz Nur Spec Muffler
Suspension:
1.* Ground Control Coilovers
2.* Tokico Blue Struts
3.* Suspension Techniques - Fr & Rr Anti-sway bars
4.* Nuespeed Front Strut Brace - Polished
Transmission:
1.* Action Clutch Stage 2MD
2.* Forbidden Motorsports Custom Short Shifter
3.* Fidanza Flywheel
Brakes:
1.* Brembo blanks - VTEC- Front
2.* Acura Legend Calipers- Front
3.* Techna-Fit SS Brake Lines
4.* Slotted Rear Rotors
Gauges & Electronics
1. Greddy 60mm Electronic Boost Gauge
2. Greddy 60mm Electronic Oil Pressure Gauge
3. Greddy 60mm Electronic EGT Gauge
4. Blitz Sequential Boost Controller i-D
5.* Blitz F.A.T.T.
* = already purchased
want to break 375whp at max of 17psi
Engine:
2. Crower Rods
8. Skunk2 Cam Gears
9. ARP Head Studs
Fuel Delivery:
3.* AEM Fuel Rail
Fuel Management:
2. Romulator
3. G-Sensor
4. HondaLogger
6. ROM Editor V3
7. FJO Lambda meter
8. P28 OBD1 GSR ECU
Exhaust:
Suspension:
Transmission:
Brakes:
5.* Blitz F.A.T.T.
mntdewred
Apr 15, 2004 04:40 PM
